I’m doing the classic 400-450hp unopened 25det setup and I’m gonna sack my power fc since it doesn’t have ignition cut and you can’t do an anti lag tune on it or mafless setup.  So in your opinion what is the best ecu to get for a 25det? I constantly hear about link g4, haltech platinum pro and sometimes adaptatronic. In your opinion which is the best ecu to get? Cheers
https://www.sau.com.au/forums/topic/482115-best-aftermarket-ecu-for-rb25det/
When talking about the 'best' ECU's and Haltech in the same sentence, I wouldn't go with the platinum pro. The platinum range of ECU's were released in 2009 and are showing their age. I'm not saying they are bad, I use one myself, but they are not really modern by todays standards.
Have a look at the Elite range of ECU's and be guided by what functions you require as to what model is most suitable for you.
As for what the best brand of ECU is, it depends on what you want from it. This is the short version of what I think about them:
* Haltech - similar to an Apple product, quality products and you pay a small premium for it. The software is pretty to look at and easy to use. The hardware is more then capable of getting the job done. (I am a Haltech fanboy as I've had amazing customer support over the many years of using their products).
* Link - similar to a typical PC/Andriod product. Better value for money when compared to Apple however not as pretty to look at or as user friendly.
* Adaptronic - no longer considered a player in the game. Haltech took over Adaptronic back in July 2018 so they could get Andy Wyatt on their roster. While it's still 'technically' a separate company, it hasn't been the same since.
Probably the most important bit though, who is going to be tuning your ECU? If not you, ask your tuner what ECU they'd prefer to use for your goals and be guided by that.
  • Like 1
what sort of motorsport are you doing to need anti-lag, and what other features are you looking for to suit eg track logging, launch control, traction control etc?
Seems to me that PowerFC is the "best" ECU for almost all RB applications given its price and simplicity. You only need something more expensive if you have particular feature needs.
JEM in ingelburn, Sydney. Very reputable tuner of skylines.
41 minutes ago, joshuaho96 said:
Why do you need ignition cut rev limiting? Fuel cut is much safer for the engine.
Not gonna lie, I mainly want it for bangs, wanks and flames. But I also want it for launch control and to get rid of the lag during shifts and rev dumps and of course throttle response.I don’t plan on doing any motorsports. I also heard it’s very rough on the engine and that’s kinda what’s holding me back. I don’t want to blow thousands on a engine rebuild
29 minutes ago, Ben C34 said:
Flames mate, that's why
We think alike
Edited by IM-32-FK
MoTec M150
  • Like 1
38 minutes ago, admS15 said:
Power fc
ewww...
Minimum requirement is Nistune with Feature Pack. Has launch control, flex fuel, boost control OR WMI control (use the 3D boost table to control the WMI).
  • Haha 1
1 hour ago, blind_elk said:
Sorry, but if you aren't doing any sort of motorsport, why on earth do you need 450hp?
Power is like money, you can never have too much lol. I'm sure he'll want 550 not long after he gets his 450.
HP, similar to measuring your penis from your anus instead of from the base.
Still same size, just one has a perceived higher value.
We live in Australia, please stop using HP. We are not stupid Americans.
  • Haha 1
who is tuning & installing it?  Go with what ever the tuner recommends.
Personally Link G4+/x is my go to as have most experience with the software. They do a plugin for r33 and heaps of safety features if required will throw made flames on gear shifts & limiter
On 15/03/2021 at 1:21 PM, Murray_Calavera said:
What ECU does JEM recommend you use?
Ok I just spoke to JEM and he said go with the plat pro because they know it inside out. I found a used plat pro for $1570.
But I also found a nistune for $650 but some guy said the nistune will restrict my power to around 300kw.
Because I’m getting tired of being gapped by camrys and aurions
On 15/03/2021 at 4:26 PM, admS15 said:
Power fc
Keep it and spend the money burning a hole in your pocket on hookers and cocaine. Lifelong memories right there.
You're welcome 😉
power fc you can’t even do a e85 flex fuel tune that’s why
Just another thing. My current setup I’m going for is
3076r garret .82 t3 vband gen 2
bosch 1000c with plazmaman top feed rail and turbo smart fpr800
walbro 535
45 turbo smart external wastegate
Probably plat pro haltech
i currently have blitz return flow fmic, 3 inch turbo back with hi flow cat exhaust
stock intake and exhaust manifold
As far as the in/ex manifolds go, I’ve been told many times that the intake mani is still go for around 700hp and the exhaust manifold is good for 450hp too (Ben Moore a tuner from Victoria did a 351kw tune on a stock in and ex manifold on 20psi 3076r .82)
is it safe to run the standard head studs for 351kw on 20psi 3076r? I’ve been told they start stretching around 22-24psi
also I heard the blitz return flow restricts at 300kw. So what are some reasonably priced non return flow intercoolers I can get?
and finally does anybody know if a plazmaman top feed rail will clear the stock intake manifold and throttle body?
cheers
Edited by IM-32-FK
1 hour ago, IM-32-FK said:
$1570.
$1570 is a rort. I wouldn't pay that for that heap of shit.
Whoever "some guy" is is a knob lol. I'd go Nistune over Halal all day.
If you want the best its Motec or Emtron really.
  • Like 1
ECU's are boring. Coke and hookers are where it's at.
@Dose Pipe Sutututu can probably hook you up with plazmaman stuff and other parts you may need as well as advice. Pretty sure he had 370rwkw with stock in/ex manifolds.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
