I don't see much talk if any about them on here.
I know they are really popular in the States so they have more people talking on forums there but i was hoping a few crew on SAU have one or are keen to get one.
 Well if you come across this thread and have a V37 post a pic and say hi 😁
  • Like 2
https://www.sau.com.au/forums/topic/482161-who-has-a-infiniti-q60-q50-v37/
On 3/27/2021 at 5:40 AM, The Max said:
They look menacingly stunning but I'm not keen on their overly complex coolant plumbing for the turbos.
Just the unfortunate reality of making a turbo engine with truly modern power delivery. The W2A charge cooler adds a second coolant loop and makes things very messy in the vicinity of the intake manifold. A2A eliminates the extra plumbing and issues with coolant leaking into the engine but now you have a bunch of additional volume after the compressor that has to be pressurized to build boost.
You're right. It is an exercise in compromise. I much prefer the lesser complexity in going air-to-air and the amount of people who've reported on their coolant system spewing forth their contents after a hose failure is well-known.
It's the only reason why I would avoid buying one, despite how pornographic they are to my eye and have me lusting after one!
On 3/29/2021 at 3:26 PM, V35_Paul said:
That is so cool.
How do get to watch that event?
They used to be on TV here in NZ last season.
I'm not sure what engine they ran but I think they used the Merc engine which could of been the 2LTR Turbo.
(Please correct me if I'm wrong.)
  • 1 month later...
it is very much a performance focused hybrid, not economy focused, put the boot in and it will drive with both petrol and electric together, but won't run both together under normal driving.  When the engine is running while accelerating or cruising it has a heavy preference to use the petrol engine to drive the car and charge the battery, once there is enough charge in the battery while cruising at a constant speed it will switch to electric only and shut down the engine until either the battery charge level gets low, or you give it more throttle than it can cope with in electric only.  it shuts down the engine while decelerating and charges the battery via regenerative braking.
Will run on electric when it can while cruising up to about 105-110km/h, above that mine keeps the engine running all the time and only uses the electric motor if you put the boot in to overtake., I have heard the RWD will run on electric to cruise at higher speeds, probably due to less drive-train loss..
Otherwise it drives a lot like a conventional car, it is a normal 7sp auto, just has an electric motor and dry clutch where the torque converter normally is, transition to electric/petrol is very smooth, you often don't even notice if you aren't watching the tacho.
I haven't driven the VR powered Qs, but have heard the performance sits somewhere in between the 300hp sport and 400hp red sport.
Edited by sonicii
  • Like 2
  • 1 year later...
That sounds like the JDM models, they have the infiniti logo on the front, but 'Skyline' across the back, the hybrid wears the 350GT badge too.
That said, I didn't think the JDM models were eligible for grey import??  unless they are AuDM models that people have retrofitted with the skyline badges.
  • Like 1
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
