Hey all
Got my car tuned at JEM(Sydney)and trying to chase up the paper copy of the dyno result. I am willing to pay Someone cash. To go in there to ask for the print out. Or email
tried to get them to email it or send in text but they just keep saying yeah I’ll do it tomorrow. Even offered to pay them just for the bit of paper I don’t care what it cost I just want it.
willing to pay $100 or what ever your price is
https://www.sau.com.au/forums/topic/483243-cash-money-for-a-job-in-sydney/
On 25/1/2022 at 9:09 PM, soviet_merlin said:
Man, I feel your pain. The fact that it is such a small thing just makes it worse.
If you are still after it on 21/02 I'd be able to go past there and ask on the day.
Thanks heaps mate, I will still be waiting by then hahaha. so happy to pay you, let me know how much$ when you get it
thank you
On 1/25/2022 at 8:44 PM, sic33r said:
🤦‍♂️For when I sell the car.
looking on all the forums you post on, you have a chip on your shoulder
That makes even less sense that the sheet isn't even for you.
What is this chip you are talking about?
Anyway, how much power do you think the car makes?
On 26/1/2022 at 5:29 PM, tridentt150v said:
Should be a sheet saying what work they did, and a printout of power, torque, and EFR's, otherwise, how do you know if they did anything....asol very handy for future work and mods.
Exactly 100 percent
Just a question, but why did you leave without it ? You paid for it right ? - so demand it. Maybe they didn't save it and now giving you the run around.
I know they can't just email it off of the dyno in a pdf direct, as it'll be in a raw format that needs the mainline dyno software to convert it. They need to print it to pdf or print and scan then email, so really they're just being lasy unless they don't have the file.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
