Hello, I have an R32 Skyline GTST with an RB25DET. Yesterday I swapped out my stock injectors for new P2M 550cc injectors. I followed a tutorial online step by step, nothing went wrong. Went to start up the car and it cranks but won’t start. Popped off the fuel pressure line and no fuel seems to be going into the rail. I can hear the fuel pump kick on when I turn the key however. Any ideas? I’m not very mechanically apt when it comes to cars in all honesty, so any info would be greatly appreciated. Thanks
https://www.sau.com.au/forums/topic/483711-rb25-no-fuel-after-injector-change/
Any possibility you put the pressure and return fuel lines the wrong way around? If the pressure line is connected to the fuel pressure regulator instead of the fuel rail you will get no fuel in the rail when the pump runs
  • Like 1
Did you prime it after?
Having all the fuel out of the rail and lines means it's not just going to fire up first flick of the key. Need to get the pump to prime 3 or 4 times before trying to start.
Failing that, possibly lines mixed up as Duncan said
The lines appear to be in order. Before when I said I popped off the pressure line and no fuel came out- I touched the top line. I popped off the bottom line and fuel did spray out. So I believe fuel is getting to the rail. I primed the pump 10 times before starting and still no luck. I sprayed starter fluid into the throttle body and it started maybe half a second before giving up. I feel like I’m so close!
Do as said above just to rule it out. Then next step, if you're confident you have fuel in rail, is see if your injectors have power and if they're clicking at all.
I hear no clicking whatsoever from the injectors. They’re brand new, I double checked all the connections, fuses are good. What else could be causing them not to click?
(injector data if that helps)4D9BF9CD-AC23-4E10-9740-B3A5C42BA6F6.thumb.jpeg.c1eb751014e4eeec985b8b12f2b5e7ed.jpegFA61FBFA-40C9-42F8-B21D-CFD6B077A881.thumb.jpeg.45316b2d180725f2e9e233dc6baaa9b1.jpeg
Should have a constant 12v supply to the injectors, ecu switches the earth. Not sure how many things could prevent ecu from telling injectors to fire but there's a few
Ended up finding this fuse blown, thought that was my issue. Replaced it, tried to start her, still won’t. Switched back to my old injectors, won’t start. Double checked everything I’ve touched, and then some, and then checked again for good measure. Got an engine code reader and all it reads is ERROR. Local shop is too backed up so they can’t touch it.
I’m completely out of ideas gents. Anything and everything at this point would be greatly appreciated.
1 - What fuse was that exactly? Missing details here. Might not even be related...
2 - If you're changing injectors, what ecu are you running?
My train of thought here is for whatever reason you decided to change to 550's and you're still running a stock ecu/tune. If so, 30$ says you're issue is not no fuel, it's too much fuel... and you're engine is flooded. Just pop your sparkplugs out and see if they're wet and check if you have fuel sitting in your cylinders after cranking. This would also explain why it wouldn't start when you went back to the stock 380cc's.
Edited by TurboTapin
I have a feeling that if the OP's mechanical skillset is at a point where he thinks its ok to install higher flowing injectors while running a stock ECU, while he stated that 'nothing went wrong', I have a feeling that something did in fact go wrong during the install however his mechanical knowledge didn't allow him to realise that something was not done correctly/was damaged/etc.
If that is the case, it would probably make the most sense to take the car to a workshop for them to troubleshoot.
  • Like 2
On 6/20/2022 at 10:39 AM, the_dude said:
Not a stock ECU. Its an AEM Infinity 506. The car was tuned on the stock injectors. I installed the new injectors and before starting, had it tuned again to support the new injectors. He did everything correctly (I’m assuming).
Pop your sparkplugs out and confirm you're not getting fuel while cranking please.
Mate you need to put all the info here so we're not going in circles.
1) Have you removed plugs to see if there's too much fuel as one of the guys suggested?
2) Have you swapped fuel lines to be sure you're not mixed up as was suggested? No offence but you didn't sound remotely confident they're correct.
3) Have you checked that you have power at the injectors at all?
4) What was the fuse that was blown?
5) Have you contacted the tuner for their input considering they just tuned it and possibly missed something?
Diagnostics requires a lot of ruling things out until you narrow down possibilities, difficult to do with half the information available.
  • Like 2
On 21/06/2022 at 9:16 AM, GTSBoy said:
Are we going to take bets on some sort of blanking caps left on/in the new injectors?
or fuel hoses backwards :D
hence fuel pump fuse blowing (or I think it's the fuel pump fuse, OP was not specific on which fuse popped)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
