Plan now is to get it 100% road legal. In NZ we have to get the car certified for the mods. This basically involves a thorough inspection, road drive etc. Technically my car was already certified but it was not done with engine mods (just suspension), so things like the dash, keypad and wastegate will be a dead giveaway… we also have to cert the wheel sizes, so by me just going from 17s to 18s would also trigger a re-cert.
  • Like 1
Do they do an emissions test too?
I know if I tried with my car I would need to make it quieter, run smaller wheels, install a 400 cell cat, plumb back the catch can, reinforce the body work for the FMIC piping cut out, etc.
So much harder in NSW, Australia. Other states in Australia are a bit easier.
No, no emissions test and you only trigger the need for a cat converter if you do an engine swap (hence i dont have one). A catch can is a bit of a grey area at the moment, how i read the legislation i have to, but the cert guy says no, so who am i to argue... I also need to install a driveshaft hoop, which has been made and ready to go on.
  • Like 1
28 minutes ago, Duncan said:
There is a driveshaft loop from factory in the middle of the shaft, it also holds the centre bearing to the body.
yeah interested he needs another one? Unless I'm reading this wrong: "I also need to install a driveshaft hoop, which has been made and ready to go on."
Yes, any cert because of a power increase triggers it (a manual swap doesn’t).the driveshaft hoop is for each section of driveshaft, as the R33 has 2 pieces it requires 2. However, as @Duncan pointed out, the rear section (if I remember right) already has one with the hanger bearing, so i only need one for the front section.
  • Like 1
10 minutes ago, Dose Pipe Sutututu said:
interesting rule!
I recall you guys have another odd one where you can run a screamer pipe, provided it goes all the way to the rear of the car and exits next to the rear muffler.
That used to be true. As long as it vented to atmosphere behind the cabin of the vehicle. I think now that all exhaust gas has to go through a muffler also.
  • Like 1
15 minutes ago, Duncan said:
Odd. The standard one is accepted in Australian racing.
You probably just need flat bar between the floor rather than a "hoop" as the tailshaft is above floor level in the tunnel
Nope, needs to be a hoop. Minimum 5mm steel. I’ll take a pic later. But yes, it is odd
Edited by R3N3
  • Like 1
Whoever is coming up with these rules need to relax the glass BBQ lol.
Sure it's for safety but surely for a car making 320kW that's clearly not needed, especially these cars the rear CVs would snap first before the tailshaft even begins to fatigue.
But rules are rules.
Here are the final dyno reports for each boost setting:
wastegate spring (7psi):
ReneNielsenFAD745Wastegatespringpressure.thumb.jpg.42bcd5fe29581981ae4a9ed83f0f144e.jpg
note that gate pressure sees the boost creep up to 12psi.
12 psi:
15psi:
20psi:
Went for a quick drive up and down the street after the tow truck dropped the car off and man it is nice. The sound of the turbo, exhaust, intake and BOV is just so nice! The power feels so linear in how its delivered.
  • Like 4
very nice power band you must be super happy, now for a flex fuel setup. Looking at the boost, and power curve, etc. there's enough headroom for near 400kW at the hubs! Power is still climbing, still room for more boost :D
(don't listen to me, you'll end up making 400kW and then the motor will go bang and you'll have a sads then do something dumb like build a motor and regrets all round)
  • Haha 1
Haha. E85 is not easily accessible here in NZ, as it’s no longer sold at fuel stations (I think nation wide now). However… I have found a supplier who can ship large drums of the BP racing corn juice. I even wired in a connector for a flex sensor in the engine bay. I am just working through the legalities around the storage of the fuel etc.
My limiting factor at the moment for more power will be my clutch. It’s a HD full face organic clutch, which is rated to around 300ish kw and 450Nm torque, which is where I am. I will start to assemble parts for my stage 2 build, which will likely be a RB30, so when it does go bang I have something ready to drop in..
  • Like 2
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
