Nistune RB20 ECU and loom
Greddy MSS for switching VCT
Yellow Jacket Coils
740cc top feed Deatschwerks Injectors
Ally fuel rail
Bosch 044 in tank
Z32 AFM in cooler piping
VH45 Throttle Body
Freddy Inlet Plenum
6boost manifold
Kinugawa (Kando Dynamics) T67 10cm T3 Rear
Tial 44mm MVR Wastegate
Stock RB25 motor
Adjustable exhaust cam gear
Greddy Profec B Spec II
Running my E42.5 (50% BP98 mixed with 50% CSR E85)
Same shit different dyno
Engine management - PFC
Boost ran - 1.4 Bar
Turbo - Garrett GT30
500cc injectors
Bosch 044 pump
HKS EVC 3
45mm Turbosmart External Wastegate
Custom Made Steam Pipe High Mount Turbo Manifold
Z32 80mm Air Flow Meter
HKS 600x300x76 Tube And Fine Intercooler
Custom 3inch Exhaust
HKS adjustable exhaust cam gearstock
etc etc etc
Fuel used - BP Ultimate
Stock Internals
The dyno graph i have is from MAS 04 as i cant find the selectamaz one where it went 324rwkw on a nice cool exterior located dyno.
:S :S
almost the same specs as me... im nowhere near that power..
Power FC
Boost : 17 psi - lower boost..
Garrett GT3076 - maybe he had a bigger rear housing, mine is .63 with the anti-surge compressor housing internal gate.
walbro 800hp rated fuel pump
700cc highflowed stock injector
z32afm
3" zaust
cooling pro stealth FMIC
blitz pod
bp ultimate
this is with a fully manualised auto, not a manual.
224.8RWKW
i think i need a new tuner...lol
ATR43SS with high pressure actuator:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
3inch turbo back exhaust
3inch intake pipe with pod.
CP pistons
Stock engine head
Stock cams
Stock cam gears
Stock exhaust manifold
Stock inlet manifold
Stock fuel rail
Stock engine block, Con rod & Crank.
Dyno run abased on 9 sec Ramp timing:
BP 98 Fuel, No boost controller, No wastegate controller 286rwkws @ 17psi.
BP 98 Fuel, No boost controller, Wastegate controller wastegate controller set at
320rwkws @ 20psi
Dyno run based on 12 sec Ramp timing with more boost maxing out the turbo, (red = 12sec, Green = 9 sec):
Make sure you know the dyno's ramp speed when comparing results, or its point less. Tricks in pointing them out is in page 73 of our high flow thread.
R34 RB25DETT Neo
CP pistons
GTR rods
stock head (just light polish on in & ex )
R34 GTR BB turbos
R33 GTR dumps
HKS front pipe
catco 3" cat
FMIC
CPC custon plenum
Haltech PS1000 + map sensor
3" HKS silent power cat back
600cc injectors
nismo fuel reg
walbro fuel pump
V-Power 98
profec b 2
not laggy at all as most people would say.
248rwkw @ 18psi
550nM of torque.
turbos are at max efficiency range, will be back at end of the year with bigger turbos to chase 300+
ECR33 RB25DET (S1)
Tomei Fuel Pump
Nismo 555cc injectors
Power FC
Z32 AFM
Greddy Front Facing Plenum (copy) with 3" Intercooler piping
3" Exhaust
HKS GT2835 KAI (0.6 Rear)
GKTech Intercooler
240rwkw @ 18psi
Will put dyno graph up soon. Bit disappointed considering results that have been achieved with the Pro S, Was told the KAI was a new improved version of the Pro S as they are discontinuing that (Pro S)
Interested to see results that others have got from this turbo, if my results are low and I have some issue, or if thats just all the turbo is capable of.
EDIT: Dyno Graph (sorry I dont have a scanner so its just a photo taken with my phone)
Edited by 89CAL
Stock rb25det S2 motor unopened installed into a HR31
Stock R33 turbo
11psi
Intank bosch 040
BP ultimate
Just jap cooler kit
3 inch turbo back exhaust
POD
Greddy profic type II boost controller
Gapped sparkplugs .8mm
Splitfires
Having problems wont make power past 6000rpm just dies off.
Going back in a few weeks with some new parts that will hopefully fix my problem.
Made 140kw lol
Redline is afm in the cooler pipe. Blue line is afm back infront of the turbo!
Turns out its my afm in the cooler pipe and its flipping out at 6000rpm! Going back soon for a little more boost to see what it will do and possablya SAFC.
ATR43SS-1 450HP profile with high pressure actuator:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
CP pistons
Stock engine head
Stock cams
Stock cam gears
Stock fuel rail
BP 98 Fuel, No boost controller, No wastegate controller 257rwkws @ 18psi.
Run below is based on 9 sec ramp timing:
With a manual boost controller set to 24 psi maxing the turbo, 265rwkws @ 20psi.
R33 s2 Gtst
Custom turbo similer to 3076 18psi
550cc sard injectors
98 octane fuel with 3 point addative
arc intercooler
apexi powerfc
triple core alloy rad
standard engine!
301 Rwkw
Edited by Abe2
R33 S2 GTS25T 271rwkw Dyno proven
Stock Engine internals
Stock manifolds
Stock head Gasket
Stock head stock cams
z32 Maf custom mounted near throttle
Power FC
Greddy Profec b2 EBC
16psi spikes 17.7psi
Highflowed Standard Turbo custom spec'ed Garrett Gt 30 Core Chra, heat wrapped
Uprated standard Wastegate Spring
3inch full length exhaust, decat, unknown muffler 5 inch tip
Splitfires coils copper plugs heat range 7
Nismo 740cc Injectors
Sard Fuel Reg
Walbro 255 intank pump
CAI Drift pod
Custom intercooler and piping standardise sizes 600x400x75
Huge triple core radiator
271rwkw @ 16psi 230rwkw@ 10psi woohoo baby and boost as early as 2200rpm stock like spool Cheetah like acceleration.
Tried 18psi but was safer AFR's at 16psi
Edited by Turbomoehican
Greddy FMIC
Power FC
HKS EVC
Xede heavy duty clutch
Pod filter
X-Force 3" high flow cat
Dump
Walbro fuel pump
Stock turbo
216.1 Kw @ 11psi (surprised everyone including my tuner)
Any suggestions on a turbo that will give me "LOWER END" performance...I would prefer a more responsive car @ lower rpm
Cheers
Greddy FMIC
Power FC
HKS EVC
Pod filter
Walbro fuel pump
Stock turbo
BP 98 octane
216.1 Kw @ 11psi
Cheers
Took some pics of my dyno sheets....
r32 w/rb25det
forged internals
stempipe manifold
gt3076r .82
50mm gate
plazmaman plenum
tomei poncams
surge tank
740cc
nistune
eboost 1
E85
will fit a stiffer spring to hold 22psi flat and make more power.
but really wanna try getting the boost on earlier. any ideas?
R34 GT-T
RB25DET Neo
Fujitsubo Turbo back exhaust, JJR 1 piece dump pipe, Catco metal 3" cat
Apexi Pod Filter with 3" hard intake
Z32 AFM
Nistune ECU
BP Ultimate
Trust Turnflow Intercooler
Hypergear ATR43-SS1
244rwkw with amazing response!
Nice dyno,
Especially the comparison to the standard turbo ...
Though one has to keep in mind that you obviously limited the boost
while running the standard unit.
I have attached a dyno (with the standard turbo) and this unit makes actually comparable boost till 4500 rpm.
(and it does so for me for 2 years now :)
Also I'm just using the standard R34 SMIC, and standard airbox.
I am currently at 220rkw (with standard turbo and amazing response) ...
R34 GT-T
RB25DET Neo
Z32 AFM
Nistune ECU
BP Ultimate
Hypergear ATR43-SS1
Edited by Torques
  • 3 weeks later...
S1 R33
standard motor
power fc
500cc high flow standard injectors
walbro fuel pump
Z32
yellow jacket coil packs
gizzmo boost controller and adjustable wastegate
chinese stainless copy manifold
Custom dump into 3" exhaust with an x force ceramic cat
factory air box with k&n panel filter and R31 inlet and snorkle in the front
custom afm to turbo pipe
GT3540 .8 rear .5 front
Power is being held back by the xforce cat, ther centre muffler (atleast 7 yrs old) and intake pipe may be hindering a little as well, once these are done it should hit around 280rwkw safely.
this power was made with the airbox lid off, wanted to know how restrictive the air box lid was, made 251rwkw with the lid on.
Although i wanted to see over 300rwkw i am happy with the outcome, my last tune got me to 220rwkw with the afm and injectors maxing out, the sheet shows only 30rwkw more but it actually feels more like 80 or so, massive difference!
http://www.skylinesaustralia.com/forums/uploads/monthly_05_2011/post-27276-0-03581500-1305184769_thumb.jpeg
Edited by W0rp3D
R34GTT RB25DET 293.4RWKW
Garrett GTX3071R .82
Siemens 630cc Injectors
HKS Front Mount Intercooler
HKS SSQV
HKS Pod Filter
ACL Bearings
Z32 AFM
Walbro Internal Fuel Pump
Greddy Profec E-01 Boost Controller
Apexi PowerFC with Hand Controller
3.5" Turbo Back Kakimoto Exhaust
3.5" High Flow Metal Cat
NPC HD 5 Puck Button Clutch
Nismo Lightened Flywheel
Edited by RBChris
Please post your RB25 dyno graphs only and state the following:
-Engine management
-Boost ran
-Fuel used (pump or special)
-significant engine mods (eg cams)
Nistune ECU
14.5 PSI (1 bar or thereabouts)
98 RON Pump
Blitz Pod Filter with Custom 3" Intake
HKS FMIC
Hypergear ATR43G2 Turbo
Bosch 044 Fuel Pump
Splitfire Coilpacks
3" Turbo back exhaust (gutted cat - I really should get a de-cat pipe because the stock cat has a diameter of 2.25" causing a restriction)
Standard Injectors (@ 85% injector duty)
Standard AFM (maxed out)
228.4rwkw
Racepace Tune.pdf
r33 s2 rb25
3" turbo back exhaust,
metal intake
walbro 255l
z32 afm
z32 ecu
nistune
nismo 550s
gtr front mount
Garret gt3076R 52t .82 IW
270 @ 16psi
really keen to see what a set of poncams and big can actuator will do to it
Big thanks to Willall and AM Performance
RB legends!!!!
for me i probably would have been happy with either of the turbos. but the 52t is what i went with to be a little different, and its great. hey, the 56t may be exactly the same. As you can see 270 @ 16psi, hits nearly 18 in mid range. im thinking big can actuator and a set of poncams should be additional fun. tag on the turbo that i wrote down was 700382-10 .
i have also included a picture of the AM Performance dump pipe before it was polished. can get you a better pic if needed
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
