Stock rb25det 1997 S2 r33 GTS-t
Unopened
Stock turbo
14psi
PFC
Intank bosch 044
BP ultimate
HDi intercooler
POD
Stealth BOV
Turbosmart manual boost controller
gapped sparkplugs .8mm
Ran 222.6rwkw
Edited by 5ky-lin3
R33 GTST spec 2
Apexi air filter pod
3" exhaust
Trust downpipe
deca pipe
Iridium plugs (heat grade 7)
Dyno sheet showing BHP at the wheel, boost shows clearly the 2 stage stock boost
Dyno sheet showing BHP at the fly and torque
mods as above and:
Power FC ECU
Walbro 255 fuel pump
Japspeed FMIC
Cold air feed to air filter
Greddy Profec B II boost controller
Stock turbo at 0.8 bar
Just got my R34 tuned and dyno'd by P.I.T.S performance (Matty Spry)
RB25 NEO
Stock motor with
FMIC
Pod filter
Blitz ID SBC
Turbo back exhaust
It made 212.2hp atw on 7psi
257.2hp atw on 11psi
final run it made 266.7hp atw on 12psi
Im Happy with that (for now)
:D
Edited by LUKE R34
Car: Nissan X-trail
Engine: QR25DE+T (2.5L four)
Modifications: disco potato (GT2860rs) .64 A/R, 3" cat back exhaust + 2.5" dump, FMIC, EMS Stinger.
98 pump fuel
0.7bar
255.3whp in 2WD (front wheels)
223.7whp @ all four.
Coming soon: .86 housing, Tial external gate, log manifold, 3" dump, fuel reg, .8bar
Hoping for 280hp at the fronts and about 250hp@ all four.
R33 GTST series 2
HKS GT2835 ProS - HPC coated
3" dump, 3" blitz front pipe, 3.5" HKS super dragger
550cc sard
ARC intake
98 ULP
unopened RB25
std cams
289.3rwkw @ 19psi
check out signature for full specs...
Edited by 75coupe
421.3 HP / 314.16 KW @ 20 PSI 93 octane pump gas
RB25DET (R33 Series 2) powered S14 240sx
Wiseco 20 over forged pistons
Eagle Rods
ACL bearings
ARP studs
Cometic HG
Tomei Poncams
Tomei adjustable exhaust camwheel
Bullseye S362 Turbo
Custom 3" Exhaust
Greddy Intake w/Q45 TB
Lovefab Exhaust manifold
HKS GT-II 60mm wastegate
HKS SSQV BOV
LS2 Truck Coil Conversion
Denso 850cc Injectors
Nismo FPR
Walbro 255lph pump
300zx Fuel Filter
AEM EMS
and More...
Edited by radianation
Nistune RB20 ECU and loom
Greddy MSS for switching VCT
Yellow Jacket Coils
740cc top feed Deatschwerks Injectors
Ally fuel rail
Bosch 044 in tank
Z32 AFM in cooler piping
VH45 Throttle Body
Freddy Inlet Plenum
6boost manifold
Kinugawa (Kando Dynamics) T67 10cm T3 Rear
Tial 44mm MVR Wastegate
Stock RB25 motor
Adjustable exhaust cam gear
Greddy Profec B Spec II
Running my E42.5 (50% BP98 mixed with 50% CSR E85)
S2 Stagea (C34), RB25 NEO
Tiptronic auto gearbox (R34)
- Nistune'd ECU
- GCG high-flow of stock NEO turbo (OP6 housing)
- running 17PSI boost, drops off to about 16 up top
- BP98
- stock engine rebuilt, only major new parts were ACL race bearings throughout and CP forged pistons (SC3708 - the '33 ones) & rings, 1.8mm Nitto head gasket to accommodate squish area for the pistons
- side-mounted air-water intercooler (~500hp unit)
Car : R33 GTST owned for the past 8 years with 140rwkw stock standard. Now running 299.7rwkw
Mods: Excedy heavy duty cushion button clutch
Yellow jacket coil packs
Bosch 040 fuel pump
Nismo fuel reg
Nismo 550cc injectors
FMIC
Garrett 3076 with .82 rear
Custom 3 inch intake running to standard air box with K&N panel filter
S-tec low mount manifold
Adjustable cam gear
Apexi power FC with H/C
3 inch exhaust running to a very hi-flow cat, then GTR system from cat back (twin pipes) unsure of size
Greddy turbo timer
Pedders springs and shocks
Nissan 350z 18X8 wheels running 265/35/18 Hankook RS2 on the rear
RDA slotted front and rear discs with QFM HPX pads
Built RB25
Haltech E11V2 ECU
GT3582
6boost manifold
Greddy Plenum
44mm Tial gate
850cc Sards
044 in tank
Splitfire coils
3.5" custom exhaust with custom SMB muffler
Daily ride so unfortunately running ULP 98,hope with get E85 this year
Fully engineered and 100% street legal :yes:
Unopened RB25DET
Garrett GT3071R .82
Apexi PowerFC
Blitz CS FMIC
Full 3" exhaust with 'high flow' cat
Nissan S15 480cc Injectors
Z32 AFM
Custom 3" metal intake pipe
Bosch 040 fuel pump
Splitfire coilpacks
Exedy extra heavy duty button clutch
Gizzmo MS-IBC boost controller
281rwkw @ ~17psi
Full boost by 3600rpm
Dyno graph to go with my post above:
Big thanks to Trent for being patient with my setup!
96 r33 gtst s2
Stock bottom end
Hypergear tr43i turbo 0.63 rear
nismo 555 injecors
z32 afm
3.5inch kakimato exhaust
tomei poncams
tomei exhaust cam gear
tomei valve springs
tomei head gasket
nismo fuel pump
jjr intercooler
307.2 kw @ 17psi full boost at 4200rpm on caltex e85
ER34 GTT RB25DET NEO
- ARC Intercooler
- TRUST turbo back exhaust
- Garett GT3071R 0.63AR
- Tomei Poncams 260/260
- Bocsh 040 Fuel pump, 480CC Nismo injectors, Z32 AFM, Nistune Type 4 tuned by Pete from PLMS @ Morpowa
301rwkw @ 17psi on BP 98 octane
Matts Nistune car thread
Hi tuners,
I own an r32 gtst skyline........swapped for a rb25, tuned yesterday
Other mods performed whilst doing the conversion are as follows:
all parts new except the afm
garrett 3071r
apexi power fc
600cc injectors
osgiken twin plate
greddy profecb spec II
z32 afm
While it had the rb20 in it i had already done the usual bolt ons, 3" turbo back mandrel exhaust, kn airfilter in stock box, trust intercooler 600x300, walbro hp fuel pump. Never did a dyno run with old engine and gear. All aftermarket gear mentioned here stayed in the car.......exhaust slightly modified.
here is what power i made, remembering 40 degree heat and wheel spin. Oh yeah 17psi and 98 octane
First pic is power and boost, second is power and a/r
Edited by mii11x
Stock rb25det S2 motor unopened installed into a HR31
Stock R33 turbo
11psi
Intank bosch 040
BP ultimate
Just jap cooler kit
3 inch turbo back exhaust
POD
Greddy profic type II boost controller
Gapped sparkplugs .8mm
Splitfires
Having problems wont make power past 6000rpm just dies off.
Going back in a few weeks with some new parts that will hopefully fix my problem.
Made 140kw lol
Hey all.
Just saw this thread and thought i'd post up what mine is running.
I've got a standard RB25 with a cometic race head gasket.
Turbonetics .69 series Turbo
740cc injecyorsGreddy topmount manifold
Greddy inlet manifold with 90mm throttle body
splitfire coil packs
Trust frontmount intercooler 4"
4" turbo back exhaust
uprated Bosch 040 in tank pump and uprated pump in boot
Greddy Profec B boost controller
OS Geiken triple plate clutch
Map 1 - 408bhp
Map 2 - 489bhp
Map 3 - 549bhp
Edited by Deathwish
1993 R33 GTS-T
Automatic converted to manual, still automatic diff (4.363 instead of 4.11)
Power FC ECU with Nissan S15 440cc injectors and Z32 AFM
Front Mount Cooler, 3" turbo back exhaust, Bosch 040 intank.
Previous turbo was a KKR560, just swapped to a Garrett GT3076 56T with 0.82 housing and a 50mm external gate on factory manifold. Feels so much better to drive now :)
250KW at 1.1bar (16psi)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
