Off topic, but i've been recommend to try this by stagefumer11:
"ok this is a easy fix you need to turn down you full lock stopers.
you will find on the lower control arms, on the end. is a adjustment screew when you can adjust the full lock stoppers. if you have a look you will see what i mean. Its a small bolt with a lock nut also. turn these in to turn the lock less.
DO both sides as you can stress you steering rack if they arnt even. Get it pretty close and you will be fine. Also put a layer of grease on to the rubbing points, as going over bumps on full lock can be quite embarrising"
Skyline model = HR31
Wheel diameter = 17"
Wheel width = 8F/9R"
Wheel offset = +30F/+32R
Tyre size = 235/40-F 255/45-R
Stud Patern= 114.3
Modifications to fit = lose the plastic inner guards. (also have 5 stud hubs which alter the offset out about 3mm)
Hey guys, I've got stockers w/225/50/16's. But I Bolted up my mates BBS rims this arvo, may buy them off him. . .
Skyline model = R33 Gts-t
Wheel diameter = 18"
Wheel width = 8.5"
Wheel offset = +40
Tyre size = 235/40-F 265/35-R
Stud Patern= 5 * 114.3
Modifications to fit = None yet, they seem to rub at full lock on the front, parking etc, and only clear the stock front brake calipers by ~ 2mm, haven't done enough driving on them yet. . .
Anyone see any problems with this size?
I'm surprised they fit at the back to be honest.
Thanks
Interstin... dads 33 has 235/40 wit 8' wide on front and 265/35 wit 9' wide on the rear with no problems at all, gaurds havnt been rolled either... So i cant see any problems? Maybe your offset is slightly different though!
Hey jazza08, they seem ok and only one of the fronts rubs (I only have one inner guard liner), I think the offset is actually the same as the standard wheels, cos they are marked '16*6.5JJR16 40'.
Speaking to another 'Line owner this evening he reckons he used to run ten inches out back . . . No mods. . . B)
Ive seen 265s on a 10' wide rim before in a car mag, never in real life. I doubt 275s would fit with everything standard?
If you take our ur guard liner (i believe our 33 still has them) that may help also! Nothin too much to worry about unless it rubs real hard of course :)
Hey guys,
I am looking at putting a set of 19x8.5" on the front, and 19x9.5" rears on a GTS-T R33... Is this possible with maybe only lippping, or would some more extensive mods need to be made? Is this all the info you would need to answer that question too, or does the offset play a major difference?
If anyone knows I would appreciate the info.
Cheers.
woah! 17X7? I think they were designe for a FWD car like a pulsar or something as even standard R32 GTR wheels are 8 inch wide, and most 17 inch wheels for 32 GTR are 9 inch or 9.5 inch. it must look quite strange with such narrow rims on it. actually from looking at the tyre size are you sure they are 7 inch wide? any pics?
haven't looked at this thread in a while...
hmm, maybe they are 17x9's then...they don't look thin and I don't actually know where I got 17x7 from :). I will try and get a measurement myself if I can.
Hey Cowie, you have Circular wheels :), wow!..... :)
Skyline model = R32 GTR
Wheel width = 9.5"
Wheel offset = +14
Tyre size = 245/40 All 4's
Modifications to fit = None. But if i lower it more then i might have to lip the guards
I have seen 17x8's on most 33's in this thread have offsets of 32-36. If a set of 17x8's with an offset of say +45 are fitted to an R33, they would sit further into the guard, right?
Yes but more importantly the spokes would probably not clear the brake calipers at the front of the 33s.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
