On 12/7/2024 at 8:37 PM, Akira32 said:
Yep I did some more research and found this out also. Still hesitant on ordering until I find the right fitment for a stock GTR r32
A good shop should do a fitting to see what works best for your vehicle.
On 12/01/2023 at 9:19 PM, Kinkstaah said:
www.willtheyfit.com
Very useful. Or measure. As GTSBoy said, 17x9 +30 just about lines up perfect with the outside of the guard.
10.5 +22 is 27mm beyond the guard.
When you say just about lines up at the front, how many mm could I go extra?
18 X 9 + 28, 25?
33 minutes ago, Kinkstaah said:
Yeah, but... how much skinner is it? 5mm? 10mm?
It seems like the later cars will swallow something at least an inch bigger than what will comfortably fit under an R32 guard. It makes sense. The R32 standard wheel width is 6.5", and I think the R34 is 7.5" (and it is isn't, it's 7). They put on a wider wheel to ensure that there wasn't a gaping gap making the car look silly.
  • 4 weeks later...
4 hours ago, wardiz said:
What's O-disk ?
It’s just the brake clearance specs for work wheels.
Disk Type:
・A disk - Standard brake clearance
・O disk - Small brake clearance with deep rim
・L disk - Big caliper brake clearance
・R disk - Big caliper brake clearance
I’ve since found out that for R32 GTR you’ll need R-Disk to clear front brakes without spacers and rear can be O, A, or R disk.
Disk Type:
How much will they foul by?
Sorry PranK what does that mean! This is the first time I’m buying aftermarket wheels so I’m learning all the new terminology on the go haha
He means, "How much negative clearance is there between the back side of the wheel disc (or spokes) and the outer face of the brake caliper?"
Brake calipers can foul by being too large a diameter for the inside of the barrel, or they can hit the back of the disc area. People often ignore the latter possibility.
What he said ^
  • 11 months later...
On 11/08/2024 at 10:12 PM, Akira32 said:
Anyone know if this will fit without modifications for a R32 GTR?
Work S13P
[F] 18x9.5 +24 O-disk
[R] 18x9.5 +24 O-disk
Disk Type:
A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
