Hello From Canada!
I tried to get an answer from our Skyline forums in Canada but was unable to get a definate firm answer therefore I come here to ask the Skyline Pro's if these rims will fit my R32.
I have a 1990 R32 GTR..
I want to buy Volk GT-7 Rims which are 18x9 offset +12 (pcd114.3 5H) ... 245/40/18 tires
I need to know by tonight if I am going to be buying them, Will these rims Fit my GTR?? Some have told me they are too big, others have told me they were too little.. and I have also been told I will need to change the tire size and yadda yadda.. judging by this thread I believe they should fit but since I know nothing about wheels I'm asking for a definate answer from someone who knows better.
Thank you so very much!
Alex from Montreal :)
Edited by Ti Pit
  • 4 weeks later...
Skyline model = 1996 R33 GTST
Wheel Brand = Volk TE37
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +22
Tyre size = 235/45/17
Modifications to fit = None (front wheels lightly nudge front bar at full lock, otherwise fine)
Hey all hoping that someone can confirm if these will fit with no clearance problems
Wheels i am looking at getting are 18 x 8 +30 offset they need to go on a S2 R33 GTS-T and just want to confirm that they will clear stock calipers, dont need the gaurds rolled and don't need spacers... being a +30 offset does that just mean they will sit out a little more... hopefully still with in the gaurds
Any help would be appreciated :)
Cheers Leigh
yes +30 means they will sit out further, but does not mean it will clear ur calipers. To determine that, you will need to find out what disk type the spokes are...ie: O disk, A disk or R risk. You can have two wheels with identical offsets and widths but if one is O disk and the other is A, you probably find the O disk won't clear. This is normally located on the sticker or stamped on the inside of the spokes. If that info is not available anywhere, the only way to find out is a test fit :)
Refer to pic below:
Assuming they clear the calipers, 18x8 +30 should sit nicely within the guards on a GTST.
I learnt this through going through various diff jap offsets and wheels and having 4 pot calipers on the front for GTT brakes makes it that much harder to determine whether a wheel will fit or not.
Skyline model = R33 GTR
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +20
Tyre size = 275/35/18 all round
Modifications to fit = none!
i would not go much wider at the front....but the car looks sexy...
Edited by frankxinyu
Skyline model = Oz R31
Wheel diameter = 17
Wheel width = 8F 9R
Wheel offset = 28F 32R
Tyre size = 235/45F 255/40R
Stud Patern= 4x114.3
Modifications to fit = Lipped front and rear just to be safe. Plastic guard needed chopping on drivers rear for the feul filler hose.
i got a standard r32 gtst sittin on stockies wif coilovers. back wheel sittin inside the guards abit and the front guards jst sits on top of the wheel, im guessin 2" low. i want to get a set of starcroft impuls racing rims... 18s 9.5" front and back. jst wonderin if i need ne mods to the guards or lippin.. and my offset?
Edited by rb25_r32
Well i can confirm the following has no drama's
Skyline model = R33 GTS-T
Wheel = Stock R34 GT-T Rims
Wheel diameter = 17
Wheel width = 7
Wheel offset = 40 i think
Wheel diameter = 18
Wheel width = 8
Wheel offset = 30
Tyre size = 235/40/18
  • 4 weeks later...
Skyline model = 96' r33 gts25t
Rim model: Buddy Club P1s.
Wheel width = front: 8" rear: 9"
Wheel offset = 32 front, 37 rear
Tyre size = front: 235 / 45 /R17 rear: 255 / 40 / R17
Modifications to fit = none! Well on full lock the fronts use to scurb agains the plastic inner guards. So i just took them out.. no biggie at all!!
Hi all. Just thought I'd post this up as I have these fitted to my R33 25t after a 6 month wait for tyres!
Skyline model = '97 25t
Wheel diameter =19"
Wheel width =8.5" front 9.5" rear
Wheel offset =+25
Tyre size =225/35R19 Front, 265/30 rear (Dunlop Spormaxx)
Modifications to fit =Rear guards lips rolled. I had 235/35 on front when I first got these and had too much guard rub up front. 225/35 has fixed the problem it seems!
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
