1995 R33 Skyline GT-R V-Spec
N1 R34 RB26DETT
N1 Cams
N1 Block
N1 Head
N1 Oil Pump
N1 Water Pump
HKS 2835 Ball Bearing Turbos
HKS Ceramic coated Dump Pipes
HKS Pod Filters
HKS Kansai 7 point roll cage
HKS Turbo Timer
APEX'i Power FC
APEX'i Dual N1 Exhaust
2x Z32 Airflow Meters
OS Giken Cross Set Gearset
OS Giken Twin Plate clutch
ARC 100mm Front Mount
ARC Catch Can
ARC 16 layered oil cooler kit
ARC Remote oil filter kit
ARC Alluminum radiator
ARC Fuel Rail
Greddy Profec B Spec-II Boost Controller
Nismo fuel regulator
Nismo Fuel Pump
650cc Injectors
480rwhp @ 20psi, mid-11 afr's, 15deg ignition timing...
  • 3 weeks later...
'97 Stagea RSfour, Converted to r33 RB26 & 5Sp.
Tomei cams
Custom fuel rail
750cc injectors
FMIC
HKS dumps
3.5" exhaust
Magic Cat
Sard fuel pump
Apexi twin filter inlet
HKS cam gears
R33 N1 turbos
Apexi Power FC
Z32 afms
Sard fpr
Apexi avc-r
297awkw@18psi
Dyno'd at SAS in shootout mode on Dyno Dynamics 4w dyno
  • 3 weeks later...
95 r33 gtr.
blitz pod filters
new exhaust system
power fc + hks boost controller
running 15 pounds. 263 rwkw
rest is stock as far as i know :thumbsup:
will post dyno sheet when i get back from work in 2 weeks
96 GTR V-spec
Tuner
Croydon
Power 266.5 @ 18PSI on new "fuel efficent" tune (low reading dyno)
Power 265 @ 17.5-18 PSI on full fuel (Croydon dyno)
Power 244.1 @ 15PSI on full fuel (Croydon dyno)
Mods
K&N panel Airfilter
Full exhust with 5" CAT
Pair Garrett 2860-5 turbo's
Apexi Power FC
Blitz ID-3 boost controller
Jun Cam gears
Stainless dumps
Croyden_dyno_run_when_first_modded_2007.pdf
Ultimate_tune_dyno_run_22_September_2007.pdf
Edited by a20089
89 R32 GTR
MODS
HKS 2530 turbos
Sard 700cc inj
044 pump
PFC
rb25 afm's
Apexi Pods
260 degree 9.15mm lift cams
cam gears
performance valve springs
head port and polish
Arias 87mm pistons
Eagle H beam rods
Cometic metal head gasket
ACL race bearings
Tomei sump baffel
N1 oil pump with crank collar
tomei oil restrictor and extra oil drain
Ross harmonic balancer
Spilt Dumps
twin 3 into 3.5inch front pipes
3.5inch exhaust
No cat
Trust 4inch intercooler and hard piping
Greddy hard intercooler pipng
HKS evc iv boost controller
Nismo twin plate clutch
346 KW at all 4's on 17 - 18 psi tuned by CRD
Edited by OFENSV
After 3 weeks of being at Boostworx having turbo's fitted tuned etc etc I finially have the GTR back and am pretty happy with the results for the set up I have.
Mods:
R33 GTR engine
gt2860-7
550cc injectors
Sard FPR
Turbo back exhaust
Power fc
Power fc B/C
Air Pods
255lph walbro pump
This was done today..
Apparent stock turbos running 15.2psi
stock injectors
stock fuel pump
remapped comp by unknown jap shop
cat back exhaust, JASMA approved so its quiet
hks filters
and thats about it...
i was pretty shocked by the results... i think theyre not stock turbos.. maybe hiflowed examples
R33 GTR
Garrett 2860r -5 turbos
RB25 AFMs
Apexi Power FC
Greddy E0-1 boost controller
660cc Nismo injectors
Nismo Fuel Regulator
Bosch 044 fuel pump
Turbo back Fujitsubo Exhaust
290.5kw @ all four.
I'm now going to save for some poncams and cam gears, as I'd like to have full boost a bit earlier (current = 4750rpm), and hopefully be able to put a bit more timing into it to make some more power. I'd love to get 320kw or so, which is max i'd like to run on a stock motor.
Edited by TommO
  • 1 month later...
Tomei 2.8 stroker kit 86.5mm pistons
new N1 block fully prepped
Head ported on inlets exh man extruded and port matched.
T517z 8.0cm x 2
Tomei 270/10.8 procam,springs,buckets and valves
ACL race bearings
Trust down/dump pipes through nismo cat and exhaust
tomei Internal and bosch enternal fuel pumps with surge tank and sard 800cc injectors
ATI H balancer
Motec m800+ map sensors
HKS evc5
Trust drag FMIC and induction piping
Trust ext sump/remote oil clr
Tomei oil pump nismo water pump
366 (491hp) awkw @ 1.5bar on dynapack
According to HPI magazine power train losses in GTR's is 35% ( utter bullsht if this was true the car would be on fire and is an insult to the engineers that designed it
a more realistic figure would be 10% maybe 15% at the outside. This would mean the engine is outputing around 580 bhp or 440 kw. HPI would say 750 bhp or 575kw)
The impression is that there is an obsession with max power in Australia which in the scheme of things means fk all the seppos are the same whereas the rest of the world
is not overly concerned with peak power but how it is delivered. HPI should stop selling bullsht magazines with false power figures . Gives young impressionable people the wrong ideas.
Torque/power curve in real world is much further to the left as full throttle not applied on dynapack till 3000rpm
Response can be increased considerably with vernier cam pully adjustments .. set up now for midrange.
Edited by ike
its a hybrid so i thought id post in both forums :yes:
Car: 1989 cefiro
Engine: rb25/rb26 hybrid
Power: 580whp 434ft/lbs TQ @ 1.2bar C14 (114 M.O.R leaded) gas
Performance Mods:87.25mm wiseco forgies 9.8:1, egale H beam RB26 rods, acl bearings, N1 oilpump, R32GTR crank:with custom collar, block line bored, and extra oiling for 26 crank, head quench removed, three angle valave job, hks 272 dur 8.5 lift cammies, hks springs & retainers, Tomei adj cam gears, tomei 2mm head gasket, ARP head studs, GReddy TD06H-25G 16cm turbine, GReddy SS exhaust mani, GReddy GT 50mm wastegate, 555cc injects, rb26 power fc de-jetro, Splitfire coil packs, GReddy intake Mani with Q45 TB, nismo intank fuel pump, bosch inline fuel pump, nismo fpr, power enterprise timing belt...etc...
Dynoed:UNNATURAL INC. Portland, Oregon, USA
When: NOV 12 2008
Mode:awesome
Just bought my GTR.
Mods include:
HKS T45s turbo Rebuit
HKS 55mm Wastegate
HKS power intake pipe
HKS low rise manifold
HKS pipework and intercooler
3 inch exhaust system
CP Forged Pistons 86.5mm and rings
HKS 264' in\ex cams
Adjustable cam gears
High flowed ported and polished head
Stainless steel multilayered head gasket
R33 reman crank (larger oil galleries)
Eagle Rods
ARP main studs
ARP enlarged head studs
N1 oil pump
N1 water pump
Tomei oil restrictor
Block crack tested, honed and decked
ACL race bearings
New Gates T belt and genuine idler and tensioner
APEXI Power FC
HKS 550 injectors
Super Direct ign coils(red)
Braided enlarged fuel lines
NIZMO Fuel pump
NIZMO fuel reg
401.7rwhp on 14psi
Tuned on V-Power Racing fuel (100 RON) by Matt Spry at PITS
89 R32 GTR
HKS GT-SS turbos
Apexi PFC DJetro and hand control
Greddy e01 EBC
Sard 700cc injectors
SARD fuel pressure regulator
HKS fuel rail (shiny purple - doesn't do much else :0)
Bosch 044 fuel pump
Tomei Poncams 260 9.15mm
HKS adjustable cam gears
M's sainless pods
Tomei bell mouth dumps
Blitz front pipe
Blitz NUR spec R catback
3" X-Force Cat
*stock bottom-end
381 RWHP @ 18psi
Tuned by Hyperdrive
R34 GTR non V-Spec
Apexi Power FC
Apexi Air Filters
Greddy Profec B-Spec 2
Nismo Air Flow Meters
Nismo Radiator
HKS GT Intercooler
HKS 2530's
100mm Catback Exhaust
Impul Front Pipe
Sard 650cc(i think) Injectors
Sard Fuel Regulator
Walbro Intank Pump
Tomei Type B Poncams
Tomei Cam Wheels
Tomei Manifolds
Tomei Dumps
Tomei Fuel Rail
314kw atw on 18psi on first tune.
BNR32
-stock turbos and dumps
-pods
-cat-back exhaust
-power fc
237.9kw @ all 4 on 1 bar.
Planning a single in the next few months so should be a bit of a gain :(
Edited by Tomek
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
