1993 Nissan R32 GTR
Apexi Power FC
Trust Front Pipes
X Force 3.5" Hi flow Cat
Veilside 3.5" cat back exhaust
Greddy Profec EBC b spec II
HKS adj cam gears
Standard Turbos
low boost: 12psi - 209kw (at all 4 wheels)
high boost: 14.5 psi - 233kw (at all 4 wheels)
Cheers to Adam and the team at Just Engine Management
  • 3 weeks later...
1992 R32 GTR
Unopened motor - 180,000klms
Splitfires
Garrett -7 turbs
Tomei adj cam wheels
R34 GTR dumps
G-Reddy Profec B II EBC
Nistune
Blitz 70mm - 80mm front pipe
Std Nissan Cat
Some sort of Jazma cat back
285RWKW @ roughly 18psi. Dyno chart attached.
Very nice set up it is too. Thanks to Status.
1382_001.pdf
-Forged Pistons (wisco)
-tomei Metal head gasket
-tomei Oil pump
-ACL bearings
-New crank
-port and polish
-tomei head restictor
-tomei sump baffle
-New belts
-Engine Blue Printed
2860-5 Turbo's
nismo Fuel pump
700cc sard Injectors
Larger FMIC
HKS Adj Cam Gears (std cams only)
HKS pod filters
custom 2.5" twin exhaust
hks twin plate clutch
power fc
332kws maxed out afm, once upgraded i will be going for 400kw
1994 R32 GTR @ 108,000kms
Before = 205kw
  • Stock turbos @ 11-12psi (up a bit due to the exhaust)
  • Stock injectors & ECU
  • Nismo Ne-1 Exhaust
  • Aftermarket fuel pump (unknown make)
  • Splitfire Coilpacks
  • Stock R34 GTR AFMs
After = 285kw
  • Garrett 2860-7 @ 18psi
  • Nistune board
  • Sard 700cc injectors
  • Tomei sump baffle
  • Mines cam baffles
  • Oil Cooler
  • 52mm radiator
E36 BMW with unopened Rb26
Stock turbos @ 12psi
walbro fuel pump
nismo 550cc injectors
Microtech LTX-12s
450x300x76 intercooler, 3" ally piping
custom stainless dumps/3" exhaust
custom intakes
Tuned by Verun at 101 here in brissy. Really happy he could prove the microtech and RB26 WORK TOGETHER!!
just a crappy bleed valve, actuators opening early hence shite boost curve - will buy a real boost controller soon.
Built by me and my mates in my shed: www.drydenmotorsports.com
1995 R33 GTR
107xxxkms
kakimoto catback
everything else stock!!
First run in red was with boost restrictor pill still in place!!! About 170atwkw
Second run removed, 30atwkw increase pretty good in my opinion!!!!
R33 Gtr block engine been rebuilt, believe it to be r33 head still
unsure of kms and internal modifications
Factory r33 turbos
Pod filters
Exhaust from front pipe back
Stock ecu
Electronic boost controller hks
Walbro pump
7.5psi - 205rwkw
10 psi - 235rwkw
12.2psi 261.3 rwkw
Rather happy with results :P more to gain with an aftermarket ecu and so on
Stoked - 305awkw at just 16.5psi, with a clutch that was only sold as good for 240kw.
24U block, probably N1 engine (so bigger cams, more finely balanced)
Nistune by Croydon Racing
R34 N1 turbos (2860-7s)
Xforce split dumps, modified to put the R32 o2 bung in a sensible location and smoothed a little
Aftermarket front pipe, 200 cell Metal Cat, 3.5 in Trust Cat back (very quiet compared to most)
Greddy Profec EBC
Seimens 550cc injectors
Trust Intercooler, about the same size at stock
Sard high volume fuel pump with direct earth
Adjustable cam wheels (but set to 0)
Otherwise stock, eg airbox, AFMs, coilpacks etc
Jim said it was very easy to tune up and make good power.
Edited by PranK
Fix img url
CP Forged Pistons
CP Piston Rings
Tomei Head Gasket
Tomei Valve Springs
Tomei Valve Lifters
ACL Race Bearing Kit
N1 Oil Pump
N1 Water Pump
Trust Sump & Oil Cooler
HKS 272/280 In/Out Camshaft
Twin Garret 2560's
HKS Fuel Rail
Bosch 044 In-tank pump
Sard Regulator
Sard 800cc Injectors
Autotronic SM4 (MAFFLESS)
Apexi Power Intake Kit
HKS Dump Pipes
HKS Silent Exhaust
HKS Boost Controller
300 AWKW (approx) at 18PSI
328.2 AWKW at 22PSI
Might be making some changes soon, - my target is 330AWKW at 20PSI.
32 GTR
- N1 block
- Jun 2.7 stroker kit (pistons, crank and rods)
- 2860-5 turbos on standard manifolds with HKS split dumps
- 10L sump
- Tomei oil pump
- N1 water pump
- Ross balancer
- full reco head fitted with Grex 264/9.3 cams, Tomei type B valve springs, Tomei cam gears
- Tomei metal gaskits
- 100mm intercooler
- Z32 AFM
- PFC computer
- tuned length stainless front pipes, high flow cat, HKS cat back system
- Sard twin entry fuel rail, Sard FPR, Sard 700's, 2 walbro pumps
I think thats most things.
It made 377 RWKW (Mainline Dyno) @24psi using BP Ultimate. Awesome mid range. :)
Motor built and tuned by Jim at DART Automotive. Very happy with his work.
My setup for the past few years.
1989 R32 GTR
- Unopened standard motor
- Standard injectors
- Standard AFMs
- HKS GT-SS kit
- HKS dumps
- HKS cam gears
- Nismo fuel pump
- PowerFC
- JustJap front pipes
- High flow cat
- Trust PEII cat-back
- Fake woodgrain cup holder
Tuned to 291.4 rwkw on the Racepace dyno @ ~16psi BP98
Motor has finally spun a big end bearing after almost 21 years, Racepace stage 1 motor on the way.
Sydney Kid RB26 build including
8.8 to 1 compression ratio
ACL 86mm Forged pistons
Eagle H Beam forged rods
ARP Rod Bolts
ACL rings
ARP head studs
ARP main bearing studs
600HP Head work
Stainless Steel Exhaust Valves
Adjustable Cam Gears (NOT Dialed in)
Balanced rotating mass
Sump Extension - Extra few Litres with full baffles
HKS 2530 Turbos
700cc 12A Turbo Injectors
Green Label AFM's
Apexi Power FC
Apexi AVCR
K&N Filters
HKS Billet Flywheel
HKS Twin Plate - Rebuilt by Jim Berry
Royal Purple Oil
Ceramic coated exhaust manifolds, turbine housing, front and dump pies
Bosch 044 Race Fuel Pump
N1 oil pump
New cambelt pulleys
Wide oil pump drive flange
Oil flow restrictors
New Cambelt
Block O’rings
370rwhp @ 20psi, not happy... But does feel solid and managed a 100-200 stint in 9.5-10secs. Still, I was hoping for at least 400.
Aaah, RE my previous post with an unhappy 370rwhp, my cat blew out the other night and turns out its a full of a fur like material....?
Anyway, it is now much much quicker, even without a dyno reading I can tell....
Also, been told the dyno I used is around 30rwhp down... so all is well :)
Edited by R31Nismoid
1994 R32 GTR
16x,xxxklms
Performance Mods:
GT 2860R -5's
Tomei Expreme Dumps
Fujitsubo Front Pipes (about 2.75in)
3 inch Decat
Fujitsubo Exhaust (about 3.5in)
ViPec ECU
Tuned by Andy Kuc at Pro Automotive in Hobart
Pushed out 270rwkw @ 17psi on normal Premium Unleaded Fuel (95ron)
Still running standard airbox with airflow meters still in place but not plugged in due to internal MAP sensor in ECU.
Standard Fuel pump, injectors, rail etc.
Still utilising the standard boost control solenoid which surprised us by holding a rock solid 17psi all the way to redline.
Engine has other mods but nothing that will alter the kw it pushes out, just make it more reliable.
This was all done to be as safe as possible so I can drive this car to work every day, take the kids to school etc and still get out and have a go on the track & at the hillclimbes of a weekend. Simply drop in some Ultimate (98ron) as a precaution and away we go.
Mercury Motorsport's R34 GTR
2.8L Engine (tomei)
N1 Block
GCG GT45R
6Boost manifold
Turbosmart 50mm gate
Autronic SM4 with CDI
Splitfire coilpacks
ID2000cc Injectors (6 off)
Magnafuel 750 fuel pump
Magnafuel reg
Hypertune 90mm plenum and throttle body
Apexi 150mm intercooler
ORC clutch
CSR E85 Fuel
Car was 100% built and tuned by Mercury Motorsport
POWER: 940hp on 37psi at all 4 wheels!
Dyno graph to follow....
R32GTS-T RB26DETT
GT2860-5's
ViPec ecu
800cc Sard Injectors
TOMEI 260 Deg Cams
Split Fire Coilpacks
Greddy Adj Cam Gears (set on zero)
Nitto I beam Rods
JE/Nitto 20th piston kit
Nitto oil pump
nitto crank collar
acl main conrod bearings
ARP head stud kit
ARP Main studs
Gates timing belt
Nitto Drag 1.2 head gasket
Jim Berry Clutch
Bosch 044 in tank pump
100mm Intercooler
Greddy Oil Cooler
10L RWD Sump
Rear Oil drain
Stainless Split Dump pipes
Greddy Y Pipe
3.5in exhaust
Tuned by JPC on BP-98 fuel.
First run-in pull at 13.5PSI. Now it needs a fuel system to wind up the boost.
2.6L machined by ADVAN with Head drain, oil restrictor etc
HKS pistons (86.5)
Eagle rods
prepped 33 crank
Trust pump
Genuine Nissan bearings
9L custom sump
Ross balancer
ARP studs
recon head with all new items
Greddy cam gears w/ gates belt
HKS cams (262)
N1 water pump
JJR coil packs w/ HKS twin spark
2x 044 pumps with surge
100mm cooler ... koyo rad ... oil cooler
Garrett T04z (.84) on 6 boost with 50mm pro gate
Link
etc etc
Summer tune little to not timing... Looking forward to winter :happy:
  • 3 weeks later...
1992 R32 GTR - 100xxx Kms
- Standard AFMs
- Standard fuel pump
- HKS Evc 6
- Garret 2860-5's, rear housings ceramic coated
- Trust extension front / split dump pipes with ceramic coating
- Ported standard manifolds also ceramic coated
- PowerFC tuned by Shaun @ Boost Worx
- High flow cat
- HKS unknown cat back exhaust (came with car)
Tuned to 290 rwkw @ 14.0psi BP98
Stock injectors running at 95% :merli:
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
