Forged rebuilt rb26
Precision 6266 t4 divided .84
GFB EX50 wastegate
Adaptronic
Greddy 264 cams
BC valve springs
2000cc injectors
Walbro e85 450lph pump
Plazmaman front mount
448kw @ 24.5psi - caltex e72
  • Like 1
  • 4 weeks later...
Standard RB26
Twin RB25 afms
Ebay intercooler
3" pretty much straight through exhaust
6 Boost exhaust manifold
GT35R
Twin 044 pumps
880cc injectors
E85
Lightened flywheel
485hp @ 7300rpm
So the RB26 has just had a birthday! my aim was for a strong reliable motor with more response and extra power if possible without losing response.
Cams 264 10.0 Inlet, 272 10.0 Exhaust
40 thou over forged CP pistons and Eagle rods
Ported head with 1mm oversize Brian Crower valves
Supertech double 90lb springs
8.9:1 compression
adjustable cam gears (which have been set)
Externally everything is the same pretty much.
Green lines on the dyno sheet are last tune and the blue line was after the build.
  • Like 1
  • 4 weeks later...
  • 4 weeks later...
N1 block Tomei 2.8 kit with cooling channel pistons
Ferrea Competition plus Plus valves and collets ..inlet valve seat 30deg cut
Tomei 260/10.25 pro cams/ A springs/Titanium valve retainers/Solid lifters/Vernier pullies set up standard specs at the moment.
9:1.0 CR 0.96mm squish squish pads retained
Garrett -5s
Nismo plenum
Standard exhaust manifolds ..untouched
HKS Racing Suction and hard pipes throughout...zero surge
Standard airbox and blow off valves with 10mm orifice plates recirc to inlet.
Trust dump ..full split version
HKS catalyzer and super turbo muffler cat back.
Trust oil cooler LH side
Trust drag R IC
Motec M800
J and S knock controller
545PS/HP (408kw) @4 wheels 64.7 kgM (467lbs)
Hioku Japan same as 98 RON I guess
Tuned at AVO Motec Saitama by Shogo Takahashi
Very happy!
Edited by Meathead
  • Like 1
Hi, I am starting to rebuild mine for response, in the Dyno charts, the BROWN is with the new PT6262 Turbo and Poncams B.260 9.15 and tune, 333.9 AWKW, BLUE is with the old T78 337.9 AWKW. Lost top power but low end is much better, good response
They said the car was getting modified for track and was a work in progress, I want a DD with grunt :)
1999 R34GTR
PT6262 turbo
HKS EVO 6 Boost Controller
Tomei poncams B 260 9.15
ATI balancer + damper
nitto h beam connecting rods
je/nitto forged pistons
nitto drag head gasket
ARP head stud/main stud kit
Head work
nitto high volume oil pump
9Lt sump conversion
Ni water pump
splifire pack
Exhaust mods,HKS dump pipe
Os Giken quad clutch
Nismo 2-way LSD
Having a stainless custom Exhaust system made for a more free flowing system, Walbro 460Lt fuel pump and Haltech Pro R34GTR ECU installed with Tune, hoping for more response and with the fuel upgrade can be tuned up for more overall power, but will give top end up for response.
Garrett -5s
Nismo plenum
Trust drag R IC
Motec M800
Very happy!
Boost pressure 145Kpa Inlet valves 30deg back cut not valve seats which are standard.
R32 GT-R build 11/92 first rego 93
fresh rebuilt RB26DETT from DART automotive 3000km ago
engine:-
tomei poncam 260 260 9.15 cams
tomei sump baffles
OS cam gears
rebuilt with new internals to DART spec (ask Jim )
TRUST extended split dumps
HKS GT-SS turbos
TRUST FMIC
baffled cam covers
APEXi FC
BLITZ SBC spec R
3.5 inch exhaust HKS rear box
splitfire coils
iri-top plugs
700cc SARD injectors
044 in tank
SARD fuel reg
remote filter and oil cooler.... now holding about 7.5 ltrs of oil...
57mm PWR radiator
power steering cooler
HICAS removed
and it goes on...
drive line is stock apart from the Jim Berry clutch, redline fliuds in the Gbox and diff, and transmaxZ in the ATTESSA with Castrol R 10/60 for the engine
fuel is BP ultimate 98
power is at all 4 @ CRD....
Pretty similar to my setup,
Rb26
Cp pistons
Eagle rods
Hks 264 , 8.7mm cams
Hks cam gears
Hks GTSS turbos
Stock dumps
Hks mid pipe and cat
3inch cat back
Stock air box
Stock gtr intercooler
Power FC
Sard fuel system
Jim berry clutch
4:36 diffs
312awkw @21psi
Currently swapping setup.
1999 R34GTR
PT6262 turbo
Head work
9Lt sump conversion
Ni water pump
splifire pack
Nismo 2-way LSD
Just had the exhaust done, new dyno
Red = Boost off
Blue= Low Boost
Orange= High Boost
  • 4 weeks later...
1990 r32 gtr
PFC
3.5 inch exhaust, unknown aftermarket dumps
Apexi pods
removed boost restrictor
rest completely stock
228kw @ 13 psi
Now with Garrett -5's
Turbosmart eboost street
289kw @ 15.5 psi
+ Walbro 460 pump
1200cc injectors
Nismo AFM's
Adjustable FPR
E85
317kw @ 18psi
  • 4 weeks later...
R32 cylinder head, R33 bottom end
Reconditioned standard pistons, rods, crank and head
Standard GT-R intake, exhaust manifold, and outlet pipes
Aftermarket front pipe
Twin Garrett GT2860R-9 (GT-SS)
Split compressor merge pipe mod
GT-R intercooler
2x Bosch 044 pressure pumps
Modified twin entry fuel rail
Injector Dynamics ID1000 injectors
Link G4 ECU
Ethanol Flex Fuel sensor
Run was done on E85, 4WD was on, boost around 18-19psi, 4th gear
AFR rock steady at 7.8:1 when converted to E85 AFR
320awkw peak
Over 300kw from 5500rpm
Over 1000nm at the wheels from about 3700rpm all the way to 6500rpm
1995 R33 GTR
Stock Internals
Apexi Pods
Apexi Exhaust
Greddy Profec
Splitfire Coils
Power FC Ecu
Garrett -5's
15psi on 98 made 230awkw with 400Nm
Now running E85 with bigger injectors / fuel pump and Tomei cam gears
Made: 312awkw with 772Nm on 18psi
1994 R32 GTR
Standard RB26
Reconditioned head
ARP head studs
Apexi Power FC
Apexi Super Suction kit
Z32 AFMS
Twin 2860R-5
Tomei Expreme Dumps
RSR Front Pipe 2.5"-3"
Tomei Poncam Type B
Tomei Adjustable cam gears
Plazmaman 76mm intercooler
Walbro 450L/h fuel pump
Sard 700cc injectors
Turbosmart Eboost2
Splitfire coils
Made 349kw @ 21-20 PSI on 98 with 1015 Nm of torque
  • Like 1
2002 Mspec Nur
Full Racepace Build motor
N1 Block
HKS Step 2 2.8 kit
Tomei Pro Cams Type B
HKS oil pump
GTX Rear housing, -5 front cover
Full HKS piping
HKS oil cooler
Nismo IC
Stock airbox with Nismo inlet & custom turbo inlet piping.
Racepace radiator
Racepace Exhaust turbo back
Fuel system
Power FC & tones of other stuff
E85
Made 447.2kw.
Will get V Cam to work in the next couple of days and hope fetching high 400's.
  • Like 2
  • 1 month later...
Fully stock 98 model S3 N1 R33 GTR with cat back exhaust.
269rwkws @ 15psi factory ECU. Front drive shaft has been removed.
Running against usual spec GTR R33.
Boost:
AFR:
  • Like 1
  • 3 weeks later...
1989 R32 Gtr
Mods:
1997 r33 vspec engine
n1 r32 steel wheel turbos
Splitfire coils
Apexi pods
Stainless cat back exhaust, some unknowm brand aftermark down pipes
Gizzmo ebc tuned to 14psi
Link g4 ecu tuned by east coast customs
164.0kw
Is it me or my car make not as much power as it should be?
  • 3 weeks later...
Ok thought I'd post up my recent tuning results
Tomei Advanced spec RB26 Crate Engine
GT2860R-5 Turbos
Mines dump pipes (ver II)
Nismo Plenum
1,000cc injectors
Midori Ti Front Pipes (80mm)
Venom 5in body HiFlow Cat
Tomei 3.5 Expreme Ti Catback exhaust system
Fuel System - two Bosch 044 pumps plumbed to dual 044 surge tank with walbro 450 as lift pump
E85 E-Flex Tune
Haltech Platinum Pro ECU
604.6rwhp @ 27psi
  • Like 3
2000 R34 GTR V-Spec
HKS GTSS Turbos
HKS Catback Exhuast - Performance Cat
HKS F-CON ECU
ID725 cc injectors
Walbro Fuel Pump
Adjustable CAM Gear
Greaddy Intercooler and After market Radiator
GReaddy hard piping kit
HKS Oil cooler and HKS catch can.
303AWKW @ 1.3Bar
http://s1244.photobucket.com/user/kushil1/media/34GTR.jpg.html
GT2860R-5 Turbos
Nismo Plenum
1,000cc injectors
E85 E-Flex Tune
604.6rwhp @ 27psi
This has definitely inspired me to do a full build on my engine from the ground up, nice work ants.
  • 3 weeks later...
Stock Crank
CP Pistons,
Forged Rods
1.2mm head gasket
100mm intercooler
Tomei Type B Cams
Tomei Cam gears
HKS 25/30s
Tomei Dumps
3.5" Exhaust
Walbro 460L pump
HKS 1000cc injectors
Nismo Fuel pressure reg
Haltech Platinum Pro with Flex sensor
98 @ 20psi 360kw
E85 @ 20 psi 418kw
E85 @ 24 psi 454kw :yes:
RB26 Dyno build
  • Like 1
Stock Crank
CP Pistons,
Forged Rods
1.2mm head gasket
100mm intercooler
Tomei Type B Cams
Tomei Cam gears
HKS 25/30s
Tomei Dumps
3.5" Exhaust
Walbro 460L pump
98 @ 20psi 360kw
E85 @ 20 psi 418kw
wowza! Onya sinistaGTR.
Great results especially with just the Walbro 460 feeding that power
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
