Above dyno sheet engine specs. I'm taking a cue from whats above so this is what I know.
N1 Block.
RPM 2.8 build. (don't know huge details)
Garret 2860-5 Turbos
RPM 4inch exhaust (twin 2.5 in tips)
HKS Vcam
HKS Cam Gears
E85 set up (Pumps etc)
Power FC
120mm intercooler
N1 oil pump
N1 water pumps.
Sard 700cc injectors
Nismo AFMs
I think thats all thats relevant. Has sump mods etc as well but figure not making a difference as far as power goes.
  • Like 2
N1 Block.
HKS Vcam
HKS Cam Gears
Power FC
120mm intercooler
N1 oil pump
N1 water pumps.
Nismo AFMs
Wow - cool setup. That must have cost a pretty penny to setup?
E85 on 700cc injectors?
I'll check on injectors as the car came with two sets and one of them was the ones we used but they may be 1000cc. Seems more likely.
It cost a bit. I'll say no more :)
Mick.
  • 2 months later...
Just got my car tuned 703rwhp 524rwkw. Does anyone know the record for these turbos?
Built bottom end with 87mm pistons
2860-5 turbos
Pon cam type A
Tomei manifolds and dumps
Apexi down pipe
ID1000s and tomei fuel rail
2 walbro 400lph fuel pumps
Nismo inlet pipes and hard intercooler pipes
Custom intake pipes
AEM series 2 ecu tuned for flex fuel
4CA2765D-A61C-43E6-9DCF-9E05E902C893_zps
2860-5 turbos
Pon cam type A
Apexi down pipe
Custom intake pipes
I think you're the record holder if the above dyno read out is accurate.....wow
2860-5 turbos
Pon cam type A
Apexi down pipe
Custom intake pipes
Really?
Judging by when that peak touqe hits they could be -10's.
Is this on std standard stroke, so a bit over 2.6?
What intercooler you running?
What exhaust?
What boost achieved that number?
Really?
What exhaust?
These are -5's I have a picture somewhere.
Block is built with 87mm pistons, eagle rods, and N1 crank
Stock Intercooler
When I bought the car the previous owner said the exhaust was blitz. The muffler says Kakimoto
We are running 25psi of boost.
Here a pic of the engine
00000000-0000-0000-0000-0000000000ED_zps
Here's a pic of the new inlet pipes
A7AF15C8-183C-4845-B030-E13041C0BC9E_zps
We are using E85. The 1000cc injectors are maxed out already so might have to change those out. Powerfab rents out the local drag strip in April to fine tune cars so I'll post trap speeds then. Also we are taking the car to another dyno this week.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
