1999 Nissan Skyline R34 GTR Vspec
Forged bottom end
R34 turbos rebuilt with gt2860-7 cores
660cc injectors
Weldina NE-1 Exhaust
Link g4 plug in ecu
19psi
BP 98
332kws atw
516nms atw
332kw on 98 with -7's? I call shenanigans.
  • Like 1
  • 3 weeks later...
Hi all just got my R33 GT-R le mans tuned.
Unopened r33 rb26 done just under 100,000 (whether it is legit or not lol)
Mods:
r34 n1 turbos
Ported stock manifolds
Split dump pipes
Xforce front pipes
100cel cat 3"
3.5" cat back
Apexi pods
Trust fmic
Hks evc-5
Link g4+ ecu (no afm's)
Siemens 660cc injectors
Nismo fuel reg
Walbro 255
OS Giken twin plat clutch
Probably more i missed.
Made 300hp on 14psi
365hp on 20psi
Was hoping for abit more after seeing some of the results here, but tuner said to do cams/gears/springs and should get near the 400hp mark.
You should only need cam gears, the cams and springs are more then fine to support over 300kw(400hp)
Might want to get rid of the split dumps and maybe check the fuel is good (i.e. The servo put the correct stuff in their pump)
  • Like 1
Thanks for your input,
will probably change cam gears next time i service it, dumps i probably should have changed when the turbos got replaced last week lol :(
and the fuel has been sitting in the tank for around 4 weeks so shouldn't be foul and i used caltex 98, but yeah possibilty of shit fuel maybe.
Depends what split dumps they are, I have split dumps on both my cars, 32 on stock turbs makes 291rwkw at 19psi and the 34 with GT-RSs on a 3.0 made 435awkw on 24psi
Does this seem low/laggy?
34R
Haltech Platinum Pro
N1 manifolds
-9s
HPI dumps and 3" front pipes
Full 3.5" exhaust after merge, catless
Stock airbox with apexi panel
E85 with 1000cc Injextors and 460lph walbro
22psi despite what graph says.
Cam gears, intake 3deg advance, exhaust 3deg retard.
Twin turbo pipe mod
Torque is oddly high also.
Rpm jumo was explained as tacho pickup on the injector wire because he can't get to the coils
I have a second graph that's fine.
Edited by ActionDan
34R
N1 manifolds
-9s
Twin turbo pipe mod
You would need to find out exactly what the revs are for us to know but going off the speed it looks like it was dynoed in 3rd or maybe 4th
My 4th goes 205@7000 but then it is a little bit longer the factory
Dropping off at 160kph seems like 3rd if it was revving around or over 7000 rpm?
4th apparently
I just liked to drive them and when they do not do what I want, i changed it until I was happy. So I guess it is up to you, if you feel the car runs great, it is great :)
Going off the Dyno I think yours looks really good and should drive great on the road and track. "Can only guess about the track, lol"
How do you like it ?
Post the 2nd graph
Twin GTX2860R 0.72 rear housings
Precision 46mm ext gates
Custom stainless steam pipe equal length high mount manifolds
Tomei oversize oil pump
ID 1000's
Twin Walbro 255's
2.5″ stainless dumps, 3" dump back
CNC Steel adjustable cam gears
Twin 6″ K&N pods
PWR Aero2 cooler with 3″ outlets
PWR twin pass X-flow 55mm radiator
PWR 21 row oil cooler
SPAL 16″ skew blade 2000CFM thermo fan
3 Quart Accusump
Custom RWD R33 GTR sump
Stock cams
Stock bottom end
Stock head
373.2kw @17psi on E85
Compression test prior to the dyno came up with 185-190 across all 6, not sure why it was so high. Tried wounding out some power but caused misfires, so wouldn't make any less.
New cams, ECU and valves coming in the next few months, no idea what it will make when retune happens.
  • Like 2
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
