  • Replies 351
If you have an L2S you don't need the wakefield licence so there is $40 saved for those who didn't realise.
I understand you are keeping the creek for the mexicans but I'd love to mix it if you have the room still closer to the day. Also be in for the Wakefield day. 1:12 flat with auto, any GTR's that don't beat it forfeit their cars to me.
Ps, I'll be running quicker than that by the time this rocks around.
fatz
Dunkan
Abo Bob
N1GTR
Moanie
Liz
Corinne
John
Just noticed that^^^ - hahaha
anyway, we have 9 confirmed for the wakefield day, that makes 30 so there is a possibility of hiring it i guess
Snowman - check the exec thread when you get a chance? cheers mate
BTW - it seems that if you have a CAMS L2S you don't need a Wakefield license. Thats what the Syd boys have told me today - although I had to get one last time so I'm confused.
Hey man nah its right, L2S overrides the wakie licence.
Well when I was there like a few months ago I didnt need to get the wakie licence as I had the L2S.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
