You are missing the fact that in victoria you are guilty untill you prove you are innocent, might sound a little sceptical but when you look at things like an epa notice for noise and emissions, they make you prove your innocence, if you dont prove it your automatically guilty (if you dont get it tested and cleared you get fined), the cops do what ever they like and its up to you to prove they are wrong.
And if you prove them wrong, you will most likely still have to pay $$ lol.
$43 for a noise test........
And if you get a major the dollars and time pile up............
How else do you think the government makes any money? considering they have sold all of our utilities to private companies now. The government doesn't have any assets! So what do they do? Charge us more!
Anyway, perhaps we need to go back on topic? :D
cheers for that,
Q:
reinforce, bit of 1mm scrap with same hole drilled on tacked/ stitched welded on underneath or exhaust tube type reinforce ?
wondering if this would be a common thing cops would defect and rwc would pass in the same state....
thanks
1mm won't be enough. Some small steel reo bar type thing will be fine.
Once you get defected, then get it engineered. I see no value in spending $600 on engineers for a hole like that until you get caught... BUT... if you reinforce it, show the cops, you might be left alone and never have to worry about it. IF you do, you've already done it and it's a simple fix (engineers).
I asked Nissan what the clearance should be and they said "100mm". So I'm not sure where this adage/myth of 'height of a Coke can' comes from?
Standard Coke cans are 130mm unless they are referring to mini Coke cans.
A rule of thumb is to check every thing you read on forums, a lot of it will be right but if it is wrong it's your arse in the line, I have seen lots of wrong advice handed out as a fact, really makes me wanna kick those people in the nuts!
hey guys got defected today :( thats all good .......... just he took pictures of catchcan (aftermarket drift brand) and didnt like how i attatched a breather to the end of the hose. and my pod filter......so my question is when they take photos...what is the purpose? are they going to investigate it? decide to epa me? just curious it was a highway patrol and he knew a lot of things....
Catch cans must be recirculating, properly made catch cans, or oil/air separators (which is what they are there for) will do the job fine when plumbed back.
Edited by W0rp3D
Take photo's as evidence of the mods.
You will get an EPA in the mail most likely.
well i got a epa in the mail today emmissions and noise.. fml..
gonna go test it see if i pass with upgraded turbo(gt2876r), r32 gtr injectors, z32, dr drift remap.. everything else is stock ....not worth it?
lol definitely won't pass.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
