Short answer was also based on little sleep in a foreign country.
The difficulty is the component you want to modify is considered a suspension component. Suspension components generally are not allowed to be modified at all. This includes welding/bending/cutting/ etc.
The reason for this is the impact/shock loading on the component will require analysis and the OEM have already completed this and strengthened this area up if it was prone to failure. By you cutting and welding in a new section, you are changing the specification and strength and in turn affecting the performance under load. This will make it prone to failure.
VASS Engineers will ask for receipts if you fit aftermarket components, so they can shift blame to the component manufacturer when you kill yourself and your parents are trying to sue the engineer. That's kind of loosely what they do, but they also have to calculate the component strength if it is modified. This takes time and requires many calculations/analysis and therefore you pay for this with an engineers certificate...
Thanks for the reply guys
as i called around i picked up some info and basically got the go ahead from at least one guy saying that i wont even need an engineers for it and if needed he will pass it easily or a new bracket made up from RHS as i happened to ask that too
you cant modify suspension components at all ( cut n weld ) but as the castor rod mount is just a bracket that bolts up i've been told that i can .
wht510,
you seem to have decent info, do you work around auto engineers or such. no chance you've mistaken the bracket for a suspension component as i'm told its fine as its just a bracket ?
Edited by Dan_J
Yes, you are right. Again refer back to previous post..,. Little sleep and foreign country makes it difficult to think!
If you were going to modify the castor rod, then no, if you were going to modify the bracket it bolts on to, then you may be OK. Depends on your mad fabrication skillz and whether or not you actually do a good job. Again, what R31Nismo administrator dude suggested is correct, speak to your engineer before you do it and get his/her/it's approval, and you should be laughing.
RWC, if you may it look factory, they wont even notice...
  • 1 month later...
Interesting experience with a defect notice recently..
Cleared it before the suspension of rego deadline, then got a letter a couple of days later (still before deadline) saying I had not complied with the notice and so they would be suspending my rego.
Called vicroads and the lady on the phone said they issued the letter as I had not cleared the defect within the one week deadline (after which time you cannot drive the car). I told her that this did not constitute non-compliance as I did not drive the car after that time, and cleared the defect prior to the suspension of rego deadline. She did not seem to understand this.
Does this make sense to anyone else? They have issued instructions and then purported to penalise me for complying with them
  • 2 months later...
hey guys, not sure if anyone has mentioned the hole people make below the washer bottle for the fmic pipe yet. any views on that one?
Don't really know what you want to know about it. you haven't made that clear. It's illegal if you have airbags I believe because it's a monocoque chassis and it changes the crumple zone and how that affects the airbag deployment. If you are thinking about cutting a hole, don't. If you have the hole already, get a return flow inter-cooler setup and weld that hole shut. If you get caught it needs engineering among other expensive things.
No need for cutting holes these days, there are many return flow options out there. I have been doing custom piping for many of the Melbourne guys, s14/15, 32-34's and c34 stagea if you have a local fabricator they should be able to whip up something legal like this... Keep the stock airbox and you are good to go.
It's been mentioned, many times.
It's illegal in any car that came with an AIRBAG.
  • 2 months later...
ok, thanks a lot guys.
just moved from nsw and unfamiliar with local rules, bought one with the hole cut without even thinking about it and kicking myself for doing so.
  • 5 weeks later...
hey. trying to get a RWC at the moment. all easy stuff they have picked up except for one thing im not sure of
when you turn the high beams on the low beams turn off. is that normal? if not any idea what the issue is?
My R33 turns off the low beams when you've put on the high beams,,, I thought this was normal?
Are you saying that your car is keeping both high beams on and low beams on at the same time?
Yes.
The OEM design has factored in the clearance from the calliper to the wheel under "normal" operating conditions.
So for example the following events occur all at the same time:
1. Wheel bearing is lose but still drivable and still to specifications.
2. Flex of the calliper is at maximum due to temperature and the driver pushing hard on the brake pedal under an emergency stop.
3. Cornering force as the driver does a maximum "G" corner acting on the stub axle/wheel/bearings/strut or knuckle etc.
4. Hitting a small pot hole while doing all of the above.
So I would find other cars with factory clearance of your particular car and replicate that. Otherwise you need to consult an VASS approve Engineer and ask them.
I can't remember the minimum clearance, but from memory it's approx 5mm from the face of the caliper, and the edge is similar. If the wheel moves more than that, then you are stuffed anyway and the clearance from the calliper to wheel isn't going to make any difference!
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
