Well 24 hrs to go and im still a 50:50. Need to get the new tyres fitted, and seat and harness on the car. Bleed the brakes and change the oil. LOL team last minute rides again. Shoudl be aout of work at around 11am so gives me the afternoon to hunt around :D
I don't care what you do Mr Brisby,
I'm in for a passenger sesstion in your car, i was advise by BEN that its a must :(!
  • Replies 307
Posted Images
Lucky? I have doen a few 14-18hr days this week and worked last weekend trying to free up time to go to PI and get this arvo to do some running around...work was quiet 3 weeks ago but now the sky is falling :P Thats why earlier this week after a technical glitch with the cat i was going to pull the pin...but fark it. In this world if you dont have a go your a mug :P
...and West, if passenger laps are a go then the passenger seat is all yours...no one else is silly enough to get in the car of the village idiot :D
Oh and need to put extinguisher back in the car :(
Ok if west doesn't make it down, i'm up for a ride in passenger lap brisby, Chris tells me after being in the passenger seat of your car at deca long-wang, he doesn't push hard enough hahah.
Brisby: You must be getting more organised, normally its 11pm you start all that shit.
I may have a passenger seat open as well if my mate doesn't come down...
I can personally vouch that a passenger lap in Brisby's car is something you'll never forget.
I can also highly recommend Xanax as the medication to help you sleep again after the experience.
That it,
I'm hype up now, i'll bring a spare undie just incase :D !
I take it back, my apologies!
although I never understand how I see your car together and working and then a month later its in pieces again!
didn't your mum ever tell you not to fiddle with your parts so much... :(:D
I don't think yours with the Black Spur and the Magnetic Fields could be any worse than Brisby's :huh:
Yeah but with me you at least know I'm not insane. I was just driving fast and the music showed I was relaxed in doing so.
With Brisby you aren't quite sure about the sanity side of things as the more he gets things wrong the more excited he gets.
Anyways...
I just thought my day was done before I'd even started tomorrow. Went back to my car after lunch to find a small river coming from underneath it and I feared the worst. Good news is it just turned out to be a split in the rear wiper washer hose and the fluid was just water from the washer tank. Hopefully that's it for issues for me this weekend.
Long Wang with Bris was a very exciting 60 Seconds of my life where I was sure it was going to be all over about 60 times.
Cars are ghey.
What's wrong mate? Your car sounded tough and strong when you fly pass us!
It was a tiring day,
well for us who had to stand flagging almost all day. The only ispired, entertained that we get is when the Fast group come out, hearing the roaring RB26 passing by was gold.....and offcourse the infamous wild animal RB20 Brisby power house screaming pass, occasionally sideway but well tamed by the beast owner himself.
Well done everyone!
What's wrong with your car mate? All i could hear on the radio was something like your intercooler hose blew off, your car was awesome as well Matt.
Thanks. yeah that's exactly what happened.. intercooler hose kept blowing off.. never happens on the dyno =( I got 4 laps in all day... 180 / 4 = $45 a lap :)
Join the club.
1 practice session and one time session.
Bloody $2 parts.
Edited by BBGTR
It's just annoying because it's the only pipe section we didn't replace... and it does have the tuff bolt style clamp on the silicon joiner because we changed all of those, but it was the pipe.. ah well, Next time.
Times are up - http://www.racetime.com.au/?event=p0701
Snowy had knock issues.
Matt had cooler piping issues.
Jack broke 5th gear but still did a 49 with just 4 gears haha
Gareth is a madman, 1.52's on street tyres!
Brisby is nuts too, 1.52 flat....
The 911turbo piped jack and aaron .... but the MPC purple GTR killed everything.
And i ended up with a 1.51 after i found some balls in the last couple of sessions thanks to gareth and some words from jack, still not enough, could of gone faster with another session dammit.
What happened to you BB?
Results are up:
http://www.racetime.com.au/?event=p0701&am...mp;view=fastest
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
