I believe the answer can be found in where the main focus is for each vehicle when it comes to competition. Look at where the SR is mainly used for track work vs where the RB is mainly used [not all the time, there are exceptions in every rule, but mainly]. Long and short circuit, drift, drags etc.
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048318
  • Replies 64
SR's used mainly for track... what about the sr 2 to 1 ratio of drift cars at nearly every drift event.
I prefer RB's because they have the potential to make more power. But sometimes I really wish Nissan got their act together and produced alloy blocks to reduce the weight factor up front.
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048438
pfttttt. sr20 FTL. when you seem them stripped down you know why there not as good. (from an engineering point of view) rockers that break,blocks that warp with a stud kit in them,single row chain thats not the greatest,good torque but not to revvy and an abundance of machining errors that cause oil leaks.
but thay work lol.
a built 20 would be my kind of engine,vs a built sr20. there just abit more tricky to get rite.
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048533
SR's a ghastly designed cheaply made bag of characterless sounding tat but it is undoubtedly torquey.
I personally wouldn't pick a SR over a CA for a road/track car and I personally prefer the RB25/26 in a S13 to either of them.
Re: the RS13 with a RB handling comments. We get this all the time on the UK SXOC. "The weight distribution is all wrong blah blah". Haven't cornerweighted my own car yet but I have seen cornerweight figures from another RB25 powered RS13 and although overall weight is obviously up weight distribution-wise they have a very similar f/r split to a S14 with a SR20DET.
They actually handle very well but theres definitely a wrong way and a right way to build them and set them up. I've been lucky enough to compare mine to a few others over here and the difference in handling was very noticeable.
When set up properly a RB up front actually adds some much needed feel to the steering and improves front end grip. Mine is noticeably less understeerey in the wet and dry on road and track than its identically suspensioned CA-powered sister car.
IMHO the RB really suits the 13, shame Nissan didn't have the balls to do one themselves. :thumbsup:
Edited by mambastu
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048587
I'd take the rb20 every time purely for the sound. The noise is very important if its a road going car and I want to enjoy the experience. I still stand by that the rb20 is the best sounding rb ever.
Edited by Rolls
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048765
The RB20 is inferior in stock form but $ for $ modding an RB will give you better performance all round. and as many have said RB's stroke allows them to rev and that's what you need with a bigger turbo.
you have to look at what is best for you.
RB is best for me...
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048824
How can you say its inferior in stock form? What do std turbo S13/14s make at the wheels? My point is a motor will only be as good as the gear Nissan gave it at the factory. In which case look at the R31 GTSR. There are RB20 with std turbo and intercoolers making 250rwkws :D
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3048911
but thay work lol.
of all the years ive been in the silvia scene, i only know of 1 broken rocker. whats wrong with the chain drive ?!
not surprisingly there is alot of bias here :D
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3049018
mmmmmmmmmmmmmmm RB20.....revs and engine note get me there :D
Not a fan of the SR, engine note sucks the wang and id rather have a tough as guts FJ20.
Good to see someone compared an RB30 to a 2JZ......always good to compare an engine origionally designed as a diesel to an over engineered freak :)
*Wheezy watches the pot stir
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3049172
It's simple, SR's have rockers...
:) cheers :)
not all of them do :D hehe ok, all the longitudinal ones do. but happines is just an RNN14 head away.
trent: I don't really know the gun SR shops in melb. but you would want someone who knows there shit installing liners that big. I'm guessing they will need to be frozen too and maybe the block heated in an oil bath and they may go in without too much hassle.
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3049189
Every SR20 has rockers, GTiR use solid lifters rather then hydrlic (spelling). I dont see the big drama with rockers unless you want to rev over 9000. They have benifites like you can fit massive cams with no modification to head etc.
https://www.sau.com.au/forums/topic/164380-sau-v-ns/page/2/#findComment-3049213
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
