All the United servos in SA have E10 100oct. While I was there today I noticed they have now dropped boost 98 e10 and replaced it with e85!!! Going to fill the jerry cans tonight to run the 180SX on it, hello 300 + rwkw :) and all on 18psi with a gt2871r!
Series? They only just got the 100 octane E10 back. Now they're getting E85?! YEAH!
Dale, no issues running the 100 octane E10. Car seems to run a bit better on it actually!
The dry spell for 100e10 was due to the floods in qld months ago, csr didn't have enough sugar cane for ethanol.
There's nothing in it between 98 e10 and 100e10 as last time I had my 180 on the dyno it wouldn't take any more timing and power stayed the same at 270rwkw.
Edited by slippylotion
it was a mix of city & highway,the mods i have are high flow turbo(stockish) high flow cat hdi inter-cooler and a k&n high flow panel air filter.ill be doing the same trip this weekend and ill try some 98 and see what i get this time around.
What mods have you done out of curiosity?
That's pretty good economy. Was it mainly highway driving or a bit of 'peak hour' thrown in there?
i get 350kms on 98 if im lucky.. neo rb25, gtr-s, nistune(untuned, but have afew different tuned maps) cooler, pod, exhaust, stock boost and with my mrs driving..
I'm in the same boat as you, I get in the 300-350km range a tank. GT35, nistune, exhaust, injectors, etc, etc. On the highway it's ok, I get to the 500 mark.
Doesn't bother me at all, my weekly average k's are about 60-70km. Some times it's 3 weeks between servo visits.
Jealous :action-smiley-069:
sounds like you have a few issues there
you'd smell a fuel leak
prob a boost leak
then get a touch up tune and make sure they re-activate the o2 sensor
Woops, I meant to say boost leak.
lol. it helps when work is 5km away and a shopping complex just down the road. i don't have to travel far to get where i'm going. it kinda makes the high fuel consumption not hurt the pocket as much. if i had to travel some of the distances you guys do i'd probably be on here complaining about it lol. but then, you don't buy a performance import for good fuel economy.
my stags on bp ulitmate, with a pod, exhaust, intercooler and nistune and i get 650km to a tank. i usually get 300km to half a tank on a hills run, then 350km driving normal
wow funny how your getting some 150 more then most RSV most are around 500 averge per tank ,
most of the autos are 400 too 450 if alls sweet,
if i have a run in hills i do half a tank to 150ks,
many say normal driving ,if your in Perth normal driving is next set of lights to get to speed limit pinch.gif ,
i hope to have a play with nistune & hope i may get 500 per tanks ,
Thats not normal driving :whistling:
PLEASE STATE IF C34,
AS VOLVO DRIVERS KEEP POSTING THERES :rolleyes:
very easy to tell look in 'Cars' section under picture of the writer, left side of screen <<< will tell you what they own haha probs get shot for this next bit but aren't all m35's auto therefore making all m35 drivers too lazy to change gears so probs to lazy to have a look that way <<< as well. Joking everybody!!! Only wrote this cause someone had to stick up for us C34 drivers :nyaanyaa:
Nope! Just the ones we can import :P They didnt produce a VQ25DET AWD Manual version of the M35 either, which makes the conversion process trickier. Some of the guys are looking in to it though :)
HAhahahhaha.. I've never understood the C34 VS M35 family fight. They are both Nissans FFS!
BOTH look like Volvos. One looks like an old volvo and one looks like a new one. :cheers:
Why can't we just get along??? :3some:
I can understand C34 owners getting upset when M35 owners rub the C34 noses in our glorious 5 speed auto box, more leg room, less cabin noise, better weight distribution, newer technology, better handling, better interior, better ride, more room in the back, better stock power and better fuel economy....... :devil:
:ph34r:
so just better in general?? :P
thats what happens when a car is 5 year newer. it has newer technology. for its time, the C34 is a fantastic car.
its like the whole R23/33/34 S13/14/15 arguments!!
Stagea cruise I was averaging about 11.7L/100km which I was happy about.
Back at work the last week & city driving, it went up to about 12.4L/100km. I drive on the Kings Highway to work through Queanbeyan, nice hills on that road as well as some stupid native fauna.
Engine & turbo are stock. Mods are HKS pod filter with heat shield, ARC FMIC, running 10 psi low boost. High is set to 14 psi but I never flick the switch over much now, unless I am stuck behing some annoying slow driver on the way to/from work & I need to overtake.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
