I would definently say you need carbs.
Your brain needs glucose.
If you are trying to build muscle/put on size I would think you'd need a reasonably large amount of complex carbs along with lots of protein.
I don't like following diets and it's pretty surprising how much healthy food you can eat without getting fat when you lift 4+ times a week.
Your body doesn't need carbohydrates to function, but it does need them to function efficiently.
If you have to abstain from carbohydrates in your diet, then you are eating the wrong carbs.
Dare i say it again, but if you eat properly, you will never have to go on a diet.
This... f**k low carb diets
For those that have asked about Albuterex previously:
http://www.tga.gov.au/safety/alerts-medicine-albuterex-xtreme-121221.htm
Looks like it might have been a lot more effectively than previously speculated LOL
no it's not a measurable difference, you can burn up to an extra 60 calories I believe
Actually you are mistaken. There is actually no such thing as negative calorie foods, despite what the health gurus like to say. Generally speaking, about 5 to 15% of our daily caloric intake is wasted on digestion. The highest burning substance is protein at about 20 to 25%. That means that if you eat 100 calories worth of protein, it will take 20 to 25 calories to digest it.
Celery on the other hand has very little nutritional value, and contains cellulose (which the body can't digest), so it takes very little energy to digest (and chewing it takes bugger all energy either, something like 10 to 15 calories per hour). So if you eat a stalk of celery (containing about 8 calories), you will only burn off 1 or 2 of those calories in the process,
http://www.tga.gov.a...reme-121221.htm
Chestbrah won't be happy.
Dam and I was going to give alburtrex a go........
In the states at the moment, haven't hit the gym for 2-3 weeks. Feeling the effects already some good and others not so much. Shit food is doing my head in as well. The yanks need some lessons on how to cook eggs and bacon
yeah I want to get to the gym as well. Far too much good food and wine with little exercise.
But..... bloody well shagged my left knee joint after it collapsed on me, twice. Hopefully just a cruciate strain or small tear, but cant tell at the moment.
Might head in anyway and try some upperbody stuff. Just dont want to stand up much atm.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
