  • 2 months later...
  • 1 month later...
  • 3 weeks later...
Hi there, planning to change all the fluids in my R34, its only been 4500 kms since i bought it and i did an engine oil & filter change after 2000 kms
i've been doing alot of reading, and window shopping for automatic transmission oils, there is alot to choose from, motul has a pretty good one for auto/semi-auto, royal purple also, but castrol transmax Z seems to be the pick around here
just wanted to hear any reasons why this might be aswell as some opinions on which is the best for my 4sp semi-auto gearbox
cheers,
danny
  • 1 month later...
decided to go penrite to see how it goes, i used sin 75 in the box, about 3.8 litres went in.
and limslip 90 in the diff, 1.4 came out (some funky purple color), 1.8 went back in.
and a bottle of nulon G90 between em.
the box was really clean as it had a little tiny bit of threat tape on each plug, so i did the same when i put em back in
Theses are the correct volumes for R33 GTST S2. Ignore what the supplier websites say.
  • 4 weeks later...
Genuine Toyota fluid, Supra has the same 6 speed Getrag (V160).. it's recommended to use the Toyota V160 fluid (http://www.chtoyota.com.au/Parts/?Page=Parts lists is as $43 per 1l), the Getrag box takes automatic transmission fluid, you could if you really wanted to and put aftermarket fluid, just make sure it's a ATF fluid not a gear oil. And stay away from Redline, it apparently has something in it that eats away at one of the seals.
  • 3 months later...
Can I fill up an R33 GTST gearbox from the gear stick. I heard I can and its only not do-able in a GTR.
Confirm/Deny anyone?
None the less, I will be getting my gearbox fluid tomorrow(castrol otherwise penrite) and some diff fluid. Might get the Nulon additive.
Just want to avoid buying a pump which doesn't work lol. I don't want to get stranded so to speak and I heard some people buying pumps from SCA/Repco which just wont suck up oil. Maybe I can remove the shifter, fit a hose down through the top of the car into the filler hole, attach a funnel and fill like that....
I'm going to buy some fluid for my box and diff. Castrol VMX looks like good stuff and I'm gonna add the G70. Is the diff easy to fill and drain? If I put a hose through the top filler hole and blow air through it, would that help get all the old oil out?
And does anyone know the torque settings for the necessary bolts? Ill go through this thread again incase its been covered.
Edit: I'm confused here, the R33 GTST has an LSD. Is it best to go for a suited LSD oil?
This is my pickup list for tomorrow:
Castrol VMX M 4 litre
Nulon G70 gearbox treatment
Castrol LSX 90 2x1L.
Am I right to go? Is there any oil I can use to make the diff tighter?
Edited by SargeRX8
Why not just use a hand pump? Might be a good idea to test the pumps out before you dump the oil too. Going through the cabin is just begging for an oil spill.
Can't remember exactly, but isn't it between the lsx90 and lsx130 or something, as the operating temp difference between the two is something like 30 degrees? The g70 can be used in both diff and gearbox too, it's good stuff.
I don't think blowing will help get much more oil out once the bulk has drained. As for torque settings I'm not sure, but don't use loctite or anything like that. Someone did on my old skyline and it caused big problems trying to get it off.
In the diff, do r33's have viscous or contact lsd's? Do they all have lsd's or just some models?
I know the 34 has a viscous lsd, but i don't think it made a difference in the diff oil choice. There's a letter on the diff number that indicates what type it is, i can't remember what it is though lol. That might only be r34's :S.
If you follow the advice on the castrol website you'll be fine, they seriously cannot afford to have the advice fking peoples cars up and ruining their rep.
  • 1 month later...
..can I use:
1-motul gear 300 for the gearbox?
2- castrol syntrax in the diffs?
3- synthetic ATF for transfer case?
Asking cos I have 2bottles each of motul gear 300 and syntrax but from the look of things I should run te syntrax in the box and put the motul in the diffs. Transfercase runs ATF?
  • 4 weeks later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
