I was just told there is a massive defect station on Maroondah Hwy outside the cop shop.. not sure what suburb that would be??.. but maybe avoid driving down there at all..
That would probably be the Blackburn/Mitcham area, cant think of anywhere else where the cop shop is on that road
spotted Chris in the gtr and Min in the Stag going down sydney rd just before craigieburn
thumbsup all round :whistling:
then a silver 33 gtr from tassie turned out of donnybrock rd and was going down hume highway
some fine cars on teh way to dutton :whistling:
Blue R33 GTS with Nismo wheels on middlebourgh Rd Doncaster
Blue R34 GT-R, looked stock, turning into blackburn Rd Blackburn
White R32 GT-R in the Dandy hills on Saturday, He gave me the thumbs up so I waved back.
All spotted on Fri
Spotted a Blue? R32 - plates UAD-XXX - around 3:15am turning off Tullamarine Freeway onto Bell Street.
Also spotted a Gunmetal R33 - plates UUQ-XXX - around 4:00pm passing my work on Apollo Drive.
parked opposite of rekin (uie710) today. always see ur car at eng carparks.
wat u studying dude?
haha yeah i saw your car there.
Studying Industrial Engineering & Engineering management (IEEM) 3rd year atm.
Course has been cancelled at uni, im the last group doing it :wub:
How bout your self? Get some sau-vic stickers :down:
It wasn't a defect station and it wasn't outside a cop shop. It was a drug bus in Ringwood, I got waved through.
The blitz was happening near Maroondah Highway and Rooks roads (Mitcham). Apparently cops and vicroads were pulling over a shitload of people like no tomorrow.
I hope no-one got dicked....
Really? I went through there and there was nothing.
Edited by llama_au
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
