spotted myself and few other skylines including blue 34 plates r34per with sau stickers getting done by TMU @ knox, full blitz on tonight.
f*kn $190 fine, EPA for exhuast 99db and bald tyres (and i had that planned to get fixed monday) :down:
ouch i was there last night didnt see any cops
Burgundy R33 - white guy and chick, on Mt Alexander Rd around 11:30 am.
White R33 driven by spec'd azn guy on Vic Pde around 5:30 pm.
Damn there are just too many R33's. I think I see about 10X more R33s than R32s and R34s put together.
pretty sure thats Darrens car
he used to live in Vic
hey nick, whats up at your end? hows things?
Yeah, thats my car, was prolly there for movies or something..
Will be coming down to melb next week for 2 weeks, gotta get outta the bank for a while...
cheers
spotted gunmetal 35 gtr on WRR heading towards sunshine way, i was coming of keilor park drive exit
plates R35GTR or sumthing
probably stolen and heading out their to be rebirthed as a Nissan Pathfinder
Nice lookin Silver R32 GTR down heatherton road last night... turned onto springy around 6:30
lol theres an old RB30 powered patrol near my shop
sounds awesome.
spotted a bright yellow R34 GTT with a bomex bar turning into edgars road from mahoneys road about 12pm yesty
Spotted a silver R35 GT-R drive past my place as I was pulling out of my driveway heading off to work... ...XCQ-***... ...I think it was another from Ferntree Gully Nissan because of the number plate surround... ...Followed him for a bit outbound on the Princess Hwy until he turned off at Ferntree Gully Rd...
He floored it past Chaddy and I got a face full of four black smoke rings...
Ohh... ...Forgot... ...Saw a green 34 turn left out of a side street near DT panels in Springvale and then turn left onto Springvale road around 2:30 yesterday... ...It looked like it had an SAU sticker... ...but I didn't get close enough to see...
Yeh, thats my baby. It needs some TLC though....building and engine for it as we speak.
RB26/30 aiming for 500RwKw mark :)
Right now its non turbo :) So don't laugh... :laugh:
Spotted a Yellow R34 GTR Vspec - Plate number 34GTRV (or something like that - I can't remember) - Had a quick chat at the lights - He is on these forums - Along plenty road at 2.30PM.
Dark blue R33 gts-t sedan and black R32 gts-t coupe at Northland Autobarn.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
