This could possibly be me. I work down near hastings and pass a white r33 gtst my way down to work and back home. I try to wave if i see the car in time. Ive got a midnight purple R33 GTR Vspec with bronze rims. Havent put the SAU Vic stickers on it yet though.
thats me!!!! ive garaged the 33 up for a while now.... using my hsv as a daily! so if you see me wave its the same guy!
Last night right next to Flagstaff Gardens I saw a bloke in a gold (maybe) 33 driving past me last night with a huge "KUWAIT" (i think) banner down the side of his car.
He gave me a few toots and got a nod.
