Mark And Duncans R32 Build
By Watermouse · Posted
Do u think Haltech will ever integrate the factory ABS into Nexus with the plug and play, eg; S3? or, is there way more practical/technical/tweeking advantages going a Bosch Msport ABS? like I grew up knowing how to jab brake, so for a street car, is it worth going the Bosch system? -
Uses the factory sensors? Which are currently the problem?
