uhhh its more likelythe owners got 3.9 gears in a commdore then it is hes got a supra making 560rwkw at ~1bar....
you can get any gears in any car, its not a big deal, i wouldnt base your answer off that
Considering it's revving to 7200RPM by those graphs...
I'm going with a worked LS2 due to the revs + torque
maybe you will all get a surprise, it does say trent LTD at the top, maybe he has put some work into his tank...
i wish, my shitter tank makes 180rwkw :( with a nice 395,596km's on the clock..... it turns fuel into noise and pollution... and of cause its a clevo...HEAT.
i must admit i now need to claim back top dog on my dyno so ive fast tracked the tank....ditched the blown clevo idea in favour of a blown windsor stroker (427) possibly twin 1.06 a/r GT35 or 10cm T67's.... parts for windsor are far easier to track down....
Here is the car in question 408cube, peter starr supercharged maloo ute..... sweet car that honestley is streetable..... mini tubbbed with custom 11" HSV wheels... and full exhaust.
will fix pics 2moro.
Has it got a madmax style supercharger clutch??? haha
Would love to drive one of these new wave of forced fed falcodores, they are real torque monsters.
and yogibear pretty sure digital cameras werent around in the 60's, and the cameras that they did have took rather good quality pictures....
Nice power.
wow 400 cubes that punches out 50 or so NM less then my 3 litre on 1.7 bar :D
.9 bar to get that kinda force is insane.... is the wick going to be turned up at all?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
