Chris - Most of my car pics from the years gone by were lost when one of my hard drives failed (which is why i now run a fully restorable raid system).. i'll try see what i can find.
  • Replies 95
I haven't got any recent stuff really, I've been completely slack and not gone to any events.
All my car related stuff is here http://www.pbase.com/willstark/cars, has some track stuff, drag day, older DECAs and drift 4 dummies.
I know what you mean about organising Calendars, at the Rex club I run the monthly photo competitions (run until Sept), then we just pick the other months from the rest. We just have one pic per moth though, so only need 12 plus cover. I guess you're doing the same as the last calendar with a montage of pics per month?
If you don't get enough recent stuff and want any of my pics, I can send you the high res versions.
The Nur in that pic is Alex's and yes he is a member. Goes under the name of Jocky (I think)
If not, his son Tim (Tim GTR).
Yep Alex is a current member and definately needs to be in this years calendar
You know.. we could just save some time & lots of effort and go take pics of all his cars.. thats enough to fill 10 calendars.. at least.. :bunny:
Anyway send the pics through, people!!
You know.. we could just save some time & lots of effort and go take pics of all his cars.. thats enough to fill 10 calendars.. at least.. :P
LOL!
Yeah he has enough cars to fill all 12 months.
Does it have to be a SAU car?
Does it have to be at a SAU event?
Or does it have to be both?
Just has to be current SAU member's car. So you can send thru any pics of your car(s)
I like this one... Thanks to Bigbird Jarrod.
Yep - I will be going through Jarrod's pics and possibly doing a morewell page.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
