So I read this article about an AWD Z33. It has a stagea diff in the front, with the atessa bits also.
http://www.superstreetonline.com/featuredv...ld_process.html
Why cant this be done for an M33? pedal box, clutch etc from a V35, box from one also, all the bits a pieces thats are required.........
I dont think it would exactly be an easy job, but to me, might be well worth it!! im guessing cost would be a big factor.
i wonder how different the RWD box is to the AWD one? is it just the rear housing??
im just speculating here.... ohh and wishing lol
Edited by zei20l
https://www.sau.com.au/forums/topic/252088-m35-manual-conversion/
yup thats probably it. and it would have been NA as well.
its entirely possible that they never had a manual option as the box may not have been able to handle the torque of the VQ25DET?
Hi Ian
Talk to Jetwreck when he gets back from Hol's. I think he has some ideas about doing this.
Cheers
Andy
Edited by andy65b
Was there no manual M35 Stagea? I saw one on Yahoo Auctions a while back and it looked factory. I just assumed it was. Maybe it was RWD.
The Stagea 350s came in a 6 speed manual, it was an Autech version. I reckon if you could get that in your VQ25DET it would be sweet....if you can get it in.......if it is suitable....if it was cheap enough ...so many if's
Jules
ohh no i dont want to go RWD, im staying AWD. im just saying compared to AWD, converting to RWD manual would be easy!
350S was AWD? but manual??
I do believed so... but all I can find now is pages like this stating it as a FR platform
http://translate.google.com.au/translate?h...l%3Den%26sa%3DG
Damn it.
Damn it.
Just had a look at that page, and it's listed the Axis 350-S using the GH-M35 chassis code, with no "N" in there, so it looks like it's RWD only... The info could be incomplete and/or incorrect, though.
Hi Ian,
I'm currently looking into this.....best option from what I can see as we basically have the R34 GTR driveline is the Getrag out of an R34. The biggest problem from what I can see is the bell housing and input shaft. I am hoping that the 350Z bellhousing will bolt up to the box but am still to confirm. Seems like a big hassle at the moment but if I can nut out the kit it should all fall into place....hopefully :happy:
The other option I am looking into is to dress up the gearbox with a better shift kit, bigger oil cooler, stall converter and maybe a manual valve body.....also putting in paddle shifters....could be the option as you would get it done for under $2,000 and if you have the resources from your own garage.
anyway have to go my boss want me to go and get pizza!
cheers
Craig
Edited by Jetwreck
well, you do it first craig and ill think about it :)
nah id like to keep the auto if possible, but im prepared to go manual if there isnt TOO much trouble.
but getting the auto box shifting a little faster would be nice!
paddle shifter is on my list already, im so lazy i dont wanna move my arm to the gear selector to change gears. yes yes i hear you, leave it in 'D', but wheres the fun in that?
  • 3 months later...
hey just thought of something......what gearbox's does the Nissan Pathfinder come with?....is there a manual gearbox? If there is it should bolt up to our motor and probably uses the same transfer case.
Part number anyone?
I'm not really into 4wd but I would have thought that the Pathfinder would have a more substantial front drive than the tiny stagea front driveshaft. Maybe the X-trail would be more likely to have something suitable? If you are keen start off by having a look under a few Nissan 4wds.
Pathfinder uses the VQ35....same spec motor as the 350Z, V35 & M35...patrol is 4.1lt isn't it?
VQ40 in the Pathy.. and the Navara, both with manual or auto.
Murano is FWD based and uses the same CVT as the Maxima, so no go there.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
