Series 2 you mean?
There is no gearbox other than the RE5 that bolts up to our orphan, I need to swap the sump so the bolts line up on the 350x box, and the starter fits. There is a lot of mechanical work before I even get to the electronic side. :/
The 350S was a series one car...
Sounds like a lot of work. Don't envy you. Starter gets moved to the other side, right?
3 times what I spent on the 350z box though. To fit the R34 gtr box you would either need the floor pan modified extensively and a new gearbox support made, or the transfer case would need to be spaced out 200mm or so off the back of the box.
Add that to the adapter required for RB to VQ, and buying a new twin plate Nismo clutch... I just can't afford it. :/
Floor pan mods are fairly straight forward, but tricky when you have to remove seats, carpet, sound deadener, looms, and then fit them all back...
Gearbox support is fairly straight forward, as a hybrid can be made between the GTR/Stagea
Custom Tailshaft required ($$$)
Gearbox Adapter would be a PITA to make from scratch, but can be bought for $,$$$...
You would have to use the GTR drive shaft to the stag diff (or get a custom one made)
Would take a fair bit of time and dollars including the purchase of the box itself.
Not to mention getting the ATTESSA clutch oil pump and all the other stuff working.
Why not Rwd ?
Massage the guards to fit some wider rubber
350z box and id say twin turbs if it has created more space presto
The rear guards will actually take quite large rubber; it has always been the limitations in the front (to keep ATTESSA happy) that have dictated the rear tyre sizes.
IIRC, several years ago, whilst auditioning rims; bbenny had 19x10.5s under the rear of his.
The only reason they didn't stay, was the issues with the ATTESSA going bezerk due to rolling dia differences with the front 19x9's & mismatched tyres.
Daleo 10.5" rear bags....
Interesting...
Well then
Apart from having total control being manual.transmission.
Myself the idea of a motec harnessing the full potential of the vq25det without that killjoy auto tranny ecu would prove irresistible.
Want to buy my 350z box and Nismo twin plate coppermix clutch now Toby? :P
I will get around to it eventually, one day when I am bored. Still searching for manual V35 interior parts... I am contemplating just using the 350z console and adapting the handbrake to work. Not sure what it would look like though.
I've always thought if I decide to heavily modify my PNM35 I'd just go RWD and 350Z manual box, but you really have to weigh up the cost of getting the car to a state you're happy with in terms of fit and finish vs the cost of sourcing and bringing in an Autech 350S. I guess you guys in Aussie have to worry about complaince though so it's probably not an option for you.
The nice Autechs fetch a tidy price. And your stuck with the shitty dash, not our nice one.
The cheaper ones are flogged out, I think its much better getting a S2 and converting. Even better if you have a RWD S2 car.
  • 3 weeks later...
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
