How does the dump fit with a different core on the turbo? or are the cores the same length?
Every thing fits the way it was, they are still your OEM housings. The T2x bearing housing is few mms short. But it doesn't affect installation.
Can possibly high flow it with a BDR351 Comp wheel working with GT45 turbine wheel. Should pump out 1200HP. What sort of housing is it in?
not sure on the rear housing size havent checked yet i would only want it to flow 1000hp anyway would the rear wheel even need changing for that?
Depending on the engine size, for 1000HP you will need a 1.2 A/R turbine housing, and 87mm 85T turbine wheel. The T04Z runns of a 74mm 76T turbine wheel which is rated to 700HP, so it needs to go up in size.
Either way its not a cheap exercise so unless your T04Z is blown, its probably worth selling it and buy the T51R which we can supply at a very reasonable price.
My concern with that is if both cores ar 2-3mm shorter than the gap between the turbos opens up 4-6mm, thats enough to mean that double layered gaskets will be needed or it will leak like a sieve.
Very good result for stock Rb20det, how come its so wavy on the top? ignition problems?
It's a hub dyno so they don't have the power dampened by the rollers which usually smooths out the curve... Plus RB20's always have a bit of a wavy top end
No ignition problems at all (had a lot more boost it in and didn't miss at all)
This was with a G2 in .63, My engine blew up on dyno during the next run. Even thou that made the power and response, I still prefer .82 for high performance RB25det. unless if that was a 3576 profile.
.63 works out ok on RB20dets.
You find Rb25det with .82 rear makes power lot easier with less boost and lot less heat.
What would lag be like though? Could it make 250kw at 120kph / 4500rpm ish like that does?
only cos for me i wouldnt be at the top of 4th much on track if at all (drift), or road so thats why i was thinking the .63 could be better for that reason?
Edited by raZ1911
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
