We normally give out a 1KG spring in the actuator. which set around 9psi. We also have a 1.2KG spring which sets it around 13psi. The bracket is $10 additional. It mounts to the side of comp housing.
This is the 2nd half of the winton footage. I actually spoted my old sil180 project on the tracks. Its also a ATR28G4 Powered CA. made 317rwkws.
Hi, Is there where the new oil line screws into? It's the only threaded place i can see, but the threads are different.
that is where you screw it in but thats the wrong end of the oil line that end that you have goes into the engine block and the other end goes into your turbo with the supplied banjo bolt
It is very important that you must use the hollow screw supplied. Not your stock oil feeding screw. Also do not use silicon glue on the buttom of the drain flange.
Yes, the glue normally gets crushed into the drain pipe and blocks it up.
Also I like to update that Powered Up options for, 2IU, OP6 and .63 ATR43 turbine housings is now available. It can increase about 15~20KWs in between 4000~6000RPM but will lose about 20% in response pre-4000RPM.
This option cost $150 Additional on top of the $800 plus GST. and comes with a 14psi Actuator.
Trent said he spent 4 hours on my car and can't fix. I'm Very disappointed with the out come. I'm going to put it back to stock get rid of it and get another R33 or R34 that works better.
Turbo seems to be holding boost fine, There're no signs of dropping off like the stock housings did, and its pretty responsive on the road.
But here's a copy of the boost curve:
With the Powered up option basically what we do is taking about 12 degrees off the turbine wheel, So it can flow more but you lose some response Pre-4000 RPM. I'm working on custom shaft at moment which is made to balance out the lag and top better.
your car get sorted on Friday?
Nah unfortunatley not, and to make it hard the car has had a knock from day one which means (A) i dont want to put it on the dyno and (b) its had previous electrical issues. If i had known all this before it was booked in for a "tune" i probably would not have touched it at all and sent it elsewhere. Sometimes i need to draw the line. I wont charge for anytime i spent on it.
Edited by URAS
Trent has been very helpful. I have nothing against them.
I was disappointed as I didn't get result I was expecting from the actual car instead found all those problems. Turbo spooled nice, early and held boost fine which is a good thing.
Any way, I'm in a process of buying a 96 Spec II R33 as my next ginny cop (why's word pi g kept turning into cop?). going to check it inside out before purchase. For me buying a cheap, aged, crappy looking car and believed the the little pricks its going to perform is just very wrong.
its guinea p1g anyways :)
Edited by Cerbera
First of all Big Thanks to Nick at Phase Auto in Campbellfield for trouble shooting and tuning. After the few dyno runs he spotted the electrical fault, and issue was fixed. Dyno results below are based on BP 98 Fuel.
This would be the first set of data for the ATR43 G3 .63 Internally gated. Today's result was abit average, taken consideration my engine compression is below 122psi. People with better engines should be able to make another 10~15KWs.
The turbo is pretty responsive, it was set to 19psi and it dropped to 17psi after 6000RPM. I'm going to do another run with .82 rear housing and compare results before cropping turbine wheel.
First set is Dr.drift remap with stock injectors and stock turbo back in May 09
Which made 205rwkws on 13psi of boost and stock ECU running 13psi of boost. The Stock turbo had half of turbine wheel missing when I purchased this car.
This is the ATR43G3 .63 14psi actuator. It run 19psi and set off at 17psi after 6000RPM.
Compare data with Dr.drift's remap and factory map with stock turbo.:
nice results there.
I have an r34 gtt and have been watching this thread closely.
im wanting to hit about 260-270rwkws through the auto.
car is a daily so cant afford to have the turbo off and send it to you etc if i can avoid it.
would using one of your .63 housings in affect be the same as using my op6 rear housing turbo?
are the quality/results the same? (Boost response/stable boost issues/flow/total power etc)
do you need me to send you compressor side also? or do you machine this yourself? (could probably pick up a cheap r33 shagged turbo to rebuild with your .63 housing?)
Whats the best option here? what are the costs?
was going to PM but thought the answers might be useful to others also
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
