stupid question.. maby... ( are there any epa problems with highflowing a stock turbo in standard housings? )
Technically you its not allowed but epa cant tell that you have hi flowed the inernals so its fine to pass a test with a hi flow.
Little update:
This is a cheap sleeve bearing rebuild option ($950 inc GST) for people with totally blown (need new core) GT3582 turbos.
what sort of power are you chasing for?
the G1 runs of a 71mm 52T comp and G2 runs off a 76mm 52T comp. For RB20 they are ok to run in .63 turbine housings.
Looking for about 220-230kw with minimal lag
Stao, i am really starting to think my turbo is causing all of my lag problems.
I have replaced all my rubber joiners, new intercooler, replaced other engine bay hoses, disconnected boost gauge and boost controller and the car is still a laggy peice of crap.
3psi by 3000rpm 10psi by around 4800rpm all done in 4th gear. I replace one last hose today and noticed the turbo side of the car is alot louder that the front or other side.
Car never had lag issue with stock turbo (Yes i know its a bigger turbo and will have more lag but not this much)
Just had a big day tuning at status. This is the first run with my new forged engine. Every thing on this engine apart from pistons are stock standard, so any good healthy RB25det will be able to do the same.
Just recap of modifications list:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
3inch turbo back exhaust
3inch intake pipe with pod.
CP pistons
ATR43G3 / Pu high flow .82
Stock engine head
Stock cams
Stock cam gears
Stock exhaust manifold
Stock inlet manifold
Stock fuel rail
Stock engine block, Con rod & Crank.
This is a controlled run based on BP 98 Fuel, No boost controller, No wastegate controller.
Car made peek of 303rwkws at 20psi with drop to 17psi (can be fixed with Gate controller). The constant was between 295 to 300rwkws.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
