No haters here...just realists...no doubt that there are some decent numbers here...the issue is with the claims of how some of these turbos offer better response and so on compared to genuine offerings...
Comparison of RPM VS Power VS Boost of some of their works with over 600 dynosheets collected for 7 years man. They are realistically outstanding. I mean there's no one ever managed to get 250rwkws with 18psi by 2500RPMS or 290rwkws with 200rwkws by 4000RPM, 320rwkws full boost by 4300RPMs, or a high flowed stockie that does 305rwkws. All with stock setup and pump fuel. If no better results are there with the same setup, then their claim aren't entirely false till some one else did better.
Garrett made their turbos to suit a large range of engines. There are plenty of room for customization suiting a specific engine setup for optimum result. That also doesn't mean what they've made would fit or runs better on other engine setups.
Like I said earlier, that sharp tip off looks like electrical caused, get that fixed, and I'm looking forward to see some results from that new ceramic BB high flow.
Edited by kwickr33
Ignore the pull down in the final 200 rpm, i use a 6900 rpm pull and the final roll off is just exacerbated by the dyno pulling the revs to a standstill @ 6900rpm. These graphs are just a snapshot of a few hours of dyno tuning i do a few runs going to 7250 or 7500 depending on the car and setup and in the case the car was slowly nosing over after 6800 (like most turbos in this size) so there is no point revving the bejeseus out of a car endlessly whilst tuning (and to keep well clear of the limiter)... so i clip it 100 rpm after the roll off. I will make sure the graphs in the future continue to within 50rpm of the limiter.
Im not buying into any arguments here as our dyno is only used to test each of the hypergear turbos (we dont align ourselves with any brands), but if your worried about the sudden drop off dont be its no worse than any other similar sized offering from other companies.. what is true is they prefer higher boost levels 22psi is the sweet spot for peak power, i like to run them around 18-19psi on customers cars which will see about 15+rwkw less than their peak, i find it keeps the intake charge more stable.
From what ive seen they are hard to beat $$ per HP.
We also found this same thing when tuning my RB20. Was a bit dull up to around 20psi, came alive at 22psi (like put on 30kw with 2psi) and then hit a bit of a brick wall...
Thanks to Trent to clear up the mass. After all those fuss The sharp drop around 6500 is just rev limiter related.
Also
Its due to the massive wheels inside small housings, same goes with the ct12 highflows that many companies do, all that achieves is a shit load of lag and maybe a 15rwkw gain overall for the soarer guys, because the housings just cannot flow enough air, so you stick a shit load of boost through them and all it does is superheat the intake air.
Not True. Depending on high flow specs. Its not just about stuffing big wheels in to small housings, Its about how to build a balanced charging system, and how to control boost. So far I've done few pairs but no one has yet sent in any dynosheets, Been told its very responsive. My estimate of them after high flowing is about 300rwkws.
Yeah I am still sorting some things out. As Tao said lots more to try. We also just discovered the front injector is causing a boost leak so that will need to get fixed before any more testing. I will have more results next thursday.
We have a few more wastegate settings to try as well as dropping the exhaust as its suspected to be a bit restrictive.
That 279rwkw is actually at only 15.8psi so plenty left in it.
Its a bit different to Tao's demo car cause all these things are sorted and you get a direct comparison.
Ok dropped my car off yesterday and Trent has fixed up the leaking injectors woohoo!! Thanks again Trent!
However, in the meantime I also returned to a stock intake pipe sleeved with a metal pipe. This was still sucking shut but in a different location closer to the turbo where it is still 2.5". The car still hits hard but once it hits 250rwkw the intake pipe sucks shut and it will not make any more power, the dyno is just a flat line after that even slightly reducing.
So off to get a custom intake pipe made up and I will post results after that. Should have listened to you Tao :D
A custom hardpipe is critical to making the power imo. The vacuum required to suck that hose in would be immense, plenty of power to be gained there...
Well it already made 279rwkw with a 3" intake that Tao helped me with. Only problem was it did not have the bov return and breather fitting so I tried the factory intake with some pipe but BAD MOVE!
wow, bit of a shitfight going on in here
mostly posting to subscribe
how long until we can expect to buy the ball bearing version?
i have suspicions that my turbo has seen better days and i was hoping to get it highflowed over summer, what would you recommend for an rb25neo that has to move a stagea about daily?
long term i'd also be happy with 300rwkw too
All the argument around the sharp power drop is just the cause from from a pre-set Rev limiter. The problem was the limiter was set to cut just before the RPM range of 7000RPM on the dyno. Which "the drop" stands for a actual fuel cut or operator throttle back off. The so called "shit fight" dated all the way back to 06 with the exact people. Which I treat it as motivation for innovation of better products.
The ceramic BB turbo is still in the process of getting installed. Its a very first prototype, I will need to run few thousand Ks with some track time before confident enough to sale it.
The highest No. we've got with a OP6 rear housing high flow was 295rwkws at this stage. Its in the updated high flow menu named the "KAI" profile. So if you are after 300rwkws high flow that or the PU profile would be recommended.
thanks for the prompt reply, i read through the last 5 or so pages but i didn't note the date on the replys
300kw is a long term goal and maybe i might end up going a 25/30 to help lug the stagea around
maybe i'll hold out for the bb core to be completed, if i get a highflow it'll be limited by the stock ecu and injectors till i can afford some aftermarket items
Honestly don't know how much you're gonna hear on a video....I have some LOLiPhone in-car footage from Pat (Randon_I_am) on the skidpan where you can hear it a little bit...his is an R34 GT-T w/ 3" metal intake...
www.facebook.com/trozzle should get you my profile, I honestly don't know if you'll be able to see the video without being my friend. If you can't see my video uploads, add me. I'll accept it and then you can have a snoop.
If your final goal is 300rwkws then its recommended to go for a turbo that can archive that, so you don't have to change turbo again when you are ready for it. And it would definitely encourage to have it happen sooner. :) . I can build with a 7psi actuator, you can exchange the actuator free for a high pressure one when you got injectors and ready to tune.
For the RB30det setup I would recommend the PU high flow or an actual ATR43 G3 or G4 in .82 and .70 comp. The larger housings will definitely help with power consistency.
Little update with the ceramic BB turbo.
Its started run and was very quite. (I thought its going to make lots bearing noises).
I took it for a quick spin. This probably one of the fastest spooling turbo I've ever had. Lot faster then traditional steel ball bearing cores I've used. It goes from 0 to 20psi in like half a second. Was like blink of an eye you are sitting on 20psi. On switch off you can hear it spins for ages before it comes to an stop.
Its currently in a .63 OP6 turbine. Should make around 300rwkws, I'll be doing some harsh testings, hopefully it just work the way it is. Will be heading towards Status for some tuning coming week for some results. (yes I will set my rev limiter higher)
will the dual BB core be available in smaller turbo's?
Yes we can build it with any sort of wheel configurations with any housings. Will only be doing it after a lengthy test.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
