What intercooler is that Harey?
Its a Trust Turnflow intercooler, although I bought it second hand so I dont know how old it is. It seems to be cooling quite well when you touch the end tanks, just seems to have a lot of pressure drop.
Hoping to replace it with a blitz return flow one day.
Awesome result.
Minor sacrifice of power off boost, then comes on song with standard turbo and doesn't let up from there. This is what the people want :)
as you can see my intercooler is quite restrictive and the gap in pressure increases with rpm. If I can get it to hold 18-19psi, I am sure I can get well into the 250's.
It has made street driving an absolute blast and it is 100% a street car.
I agree with Wolverine's observation, very similar sort of result vs the GT-RS. I went back and checked it against my old GT2871 48T high flow as well, and saw similar characteristics on the graph. That old setup only lagged behind the std setup to 2500rpm and made 225kW on 12psi. If this ATR43 SS1 offers similar transient throttle response characteristics, and this result at full load it's got to be the sort of setup a smart owner will choose. I like the look of it.
It does appear that pressure drop across the intercooler is costing some top end, but what sort of boost control is employed? An EBC may help to offset what's going on with the cooler, although turbine flow may also be part of the equation. What's the vibe from your tuner and Stao on these fronts? To be really honest it doesn't look to be want a higher peak power figure for other than bench racing. If it was able to hold peak torque from current 4700 through to 5700ish, it would have a really fat top end so you don't need to rev it hard. That would be good.
It's a street car, but also interested to know if it runs a quiet (legal)exhaust spec.
Awesome result.
This, inside a stock looking housing, is exactly what people want, or at least I want.
That, and the SS-2 Prototype which was a few pages back now which made 320rwkw with full boost at about ~3700, and you have pretty much got what 100% of all people want who arent doing massive internals work to their engine.
Oh yeah, inside the standard housing too :)
I'm not so sure it can be done with the standard housing...yet...Stao?
And if it can, it will most certainly be laggier or down on power up top.
Yep if it can be done inside a stock housing I would consider it as a replacement for my turbo should it ever die being as GCG really turned me off with their customer service.
It plots like a HKS GT-RS.
Here's SS-1 VS GTRS based on a 12 sec run as the GTRS was tuned on 12 secs ramp. We only did like 3/4 of a run as the AFM plug vibrated it self out and made a massive knock. Trent was abit scared to put it back on.
Thick red line is ss-1, thin red line and green line is GTRS
So the big question mister hypergear...can we get something like that^ put into the standard housings aka high flow?
Yes can be done. Just odd that I have to charge you $50 more for the alloy sleeve then a brand new SS-1.
Can we have a picture of a brandnew SS-1 next to a standard turbo housing? Curious how different it looks and if it would pass the EPA/Defect inspection.
It is just running off the actuator, but the boost pressure before the intercooler looks perfect flat ~21-20psi. The drop down to 20psi after 6,000rpm is even there on Tao's car. Thats just the turbo running out of puff. The issue is the intercooler pressure drop as you can see I can only get just over 15psi into the engine. The previous turbo had exactly the same behaviour, I could not get more than ~15psi into the engine no matter how much I cranked the boost up even with a large 0.82 housing! I tried EBC's and they did nothing. Trent my tuner said he reckons even if you unplugged the hose from the actuator you wouldnt get anymore boost up top (previous turbo).
I run a 3" fujitsubo catback exhaust which is very quiet, on my previous turbo it was restricting power ~5-8kw but to me its worth it so I dont get any unwanted police attention.
They share the exact same housing geometry, except the surge grove for stock comp wheel needs to go (high lighted). To use that as the SS comp housing the whole inlet part of the stock comp housing has to be machined out and resleeved to have a flat bore.
Just comparing mine to Hareys for a minute and its amazing how different yet the same they are
heres mine
Hareys
I dont have a graph but I had much the same boost pressures as well. My cooler is also pretty crappy but at the manifold I had 18psi dropping of to 15psi.
be interesting to see them side by side at the lights ;)
fantastic result Geoff!!! things have definitely improved from the guinea pig days when i ran some of the HG proto's - i made a touch more with my 98 tune, but full boost was a good 500rpm later from memory
this is the turbo for the street guys, well done Stao!
Stao what sort of results would you expect from your SS-1 at 14psi, and can you build a 'smaller' turbo into a T3 housing?
Perhaps 2871 52t spec into your .64 housing with 3 nozzle FNT tech + your .60 3" comp cover, do able?
the SS-1 should make just under 240rwkws on 14psi. I can only run a single nozzle in those as the turbine housing doesn't have enough room to run more. I believe the SS-1 is the perfect combination for 250rwkws applications. Smaller profiles is do able, but lack in peek power and torque but doesn't make any differences in response just like the GTRS comparison above. I'm pretty happy with the way its currently set.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
