Result for my SS1 PU are in:
Overall its not bad but not the best
-Peak power 244kw
-Makes about 200kw at 4000rpm (good, expected)
-Boost goes from 21psi in midrange to 17psi in top end
-Tuner reckons something is holding it back since its doesnt make that power in the top end easily however he is not sure what it is
-Tuner reckons that it comes on too hard with the current actuator so they had to massively reduce timing (which he is not happy with) so it would not ping in the mid range
-If they use the EBC at all there is too much boost low down so they are not using it
-If it had a lower pressure actuator he thinks they could run lower boost and more timing down low, then higher boost up top and more peak power
I will pick it up tomorrow morning, tuner had not yet driven it when i spoke to him.
He thinks it will feel very fast and pull hard so it may not be worth chasing more top end.
You're pushing 21psi into an RB25 and only hitting 244kw? Something doesn't seem right there.
I know boost doesn't relate directly to power, but tons of cars are making way more than that with that kinda boost.
And how does one have too much boost down low?
Boost has nothing to do with power, airflow has everything to do with power. If I put a straw as the intake on a car and hook a hair dryer up to it I bet I could generate about 30psi but the car wouldn't even idle. See what I mean?
Too much boost down low means very very high combustion pressures which can cause detonation. More torque = more chance of detonation and detonation is bad.
Yeah, but is he blowing a hair dryer down a straw? No, he's using a turbo which many others have used before him and made substantially more power than he is.
My point stands. That turbo on that engine should make a solid 20kw+ more than he's getting at that boost level (even dropping off to 17psi).
How many others have had issues with too much boost down low? I may have seen one or two but generally everyone is chasing boost coming on earlier. Sure, you don't want it banging from 5 to 20 PSI between 2500 and 2800rpm, but too much boost down low again suggests there are other issues at play, which again is my point.
Do a run without the cat. Letely i have not yet found a cat that performs to my expectations. Last night was an R33 knock limited at 188kw, dropped/gutted the cat and made 202kw safely.
Tonight was an s13 188kw 23psi. Then dropped/gutted cat and tuned to 234kw on 21psi.
NB: both these cars are race only so catalytic converters are not needed.
I do not recommend running no cat on the road as its ILLEGAL :D i dont do anything illegal
I'd like to see a graph...15-20rwkw isn't difficult to find if there's an underlying issue for it, of which there could be many. The age and wear of your engine alone means you may not be guaranteed the 260-270rwkw that a healthier engine could produce.
Do you have a baseline figure sik, i.e. a dyno run before turbo upgrade? If so, at what PSI? Are you running a 3" metal intake?
On the ss1pu it has a big turbine housing, understanding the turbo would be pushing 20psi at 3300RPMs, then the waste gate opens, that compressor is not big enough to max out the turbine wheel and waste gate at that point and knock, unless if its on a much bigger engine.
I probably check the injectors, intake pipe (make sure its metal 3 inch), cooler, and drop the exhaust for few more runs, also check the ss1PU's timing table for mapping. Was the rubber gasket replaced with a metal gasket or another rubber one?
So far we got:
280rwkws peak 22psi
260rwkws peak 19psi
253rwkws peak 17psi
and this one is
244rwkws peak 21psi
Probably a dumb question, but here goes. Do WA tuners use the same ramp rates as tuners over east? My understanding is ramp rates effect the power reading , AKA a happy dyno.
DVS Jez, luckily we all use nice eco/police-friendly catalyct converters eh? :whistling:
9-sec ramp rate is the norm. Some may use a 12-sec for whatever reason, but I'd just ask Mick what he used for your run, my bet is 9-sec same as Trent.
Don't think we are going to find answers there man :(
Haha that's right my 32 had a cat on it a decat looking one. What turbo was on the s13?
I got the ss2, made 246rwkw on 19psi. My intake pipe was 3 in metal at the turbo to the stock rubber pipe to the afm. Since that tune and run I have more been using a full 3 inch metal pipe and had to pull timing out my self on high boost due to pinging. Even after pulling out timing I feel no change in power. I yanked out about 4 to 5 degrees in some areas. JEZ I'll be visiting you soon.
i went through all my sheets recently and was suprised to see all 8 or so tunes at xspeed were done at 15 sec.
Stao- im all cashed up and need to know if the SS2 is on the table or your still not interested in producing these?
Edited by t_revz
I'm awaiting to see few more results from all 6 of those made before making a decision as this turbo performed above expectation on the test car, which can be either good or bad. So far I've got:
325rwkws peak 23psi
307rwkws peak 22psi externally gated
265rwkws peak 18psi Auto
Can every one please post up prints of their timing map for their atr43 series turbocharger. That would help us determine which tuner might be better to go for as well as how power and response responded refer to different tunes.
Maybe not hypergear, but the GCG hiflows with a 21U housing with a auto trans come on way to early and surge like a motherf**ker..
cheers
darren
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
