Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running our re-trimmed 20G Billet compressor wheel.
It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly.
Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2
Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange.
Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel.
Nice.. Why not call it HG TD06SL2 (Hypergear TD06SL2), thats less confusing..:teehee:
I take it you dont follow the kando thread cause this is what I have been saying for months... :thumbsup:
If you want a ride in my car just PM me man,...clutch is slipping a little atm but should be rectified soon..
Car is very nice smooth to drive
@ 1 bar boost, with 6 month old fuel that was still sitting in my tank.. :yes:
Yea I found it. It looks too linear thou, I pictured it would do some thing that. I should be able to add in lots of meat into the mid range with FNT turbine.
Where abouts are you based? I'm testing the ss1pu again Friday afternoon which we can swap cars for a test drive near status or unless if you are in the North side.
There is no midrange because its at one bar, lets wait and see what the 22psi graph looks like. Hurry up and get that clutch in Artz.
I'm interested to see the results with the stock 5 bolt housing. Get on to it Stao. :thumbsup:
An M35 Stagea rear may work well too... :whistling:
yeah cool, Im near dandy..I probably cant get there till about 6 though will you still be around?
I'll be there 7pm starting the tune on Friday. Its more of testing the wastegate actuator and a newer housing. Should all finish in an hour so its all good if you like to come in around 7pm and see how the tunning goes.
I will trail some externally gated ones including the SL2 and T67 combinations with billet wheels and do some modifications no housings from there.
At this stage we can supply SL2 units in 10cm T3 turbine with billet compressor wheel.
Anyone got ideas about what I should be saving for next to get a bit more put of the turbo
Also how do I get rid of the ping around 250kw
Do things like oil coolers keep the overal engine temp down to prevent this?
Water Meth Injection ;)
better (more efficient) intercooler
Freer flowing exhaust
there are a few things you can do to squeeze every last drop out, but $$$ per HP makes it rather expensive
Save for a plazaman cooler. Or a custome side mount manifold
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
