A high pressure air reservoir could be used in just that way. Would need to work out a way not to have to squirt it into the exhaust housing (ie, some other sort of additional turbine on the same shaft would be good - or, left field thinking, squirt it tangentially onto the compressor wheel and hope it spins it up without interfering with the flow off the tips of the comp wheel). In fact, it has been done before in one way or another.
But, it takes a lot of flow to drive a turbo up to speed for any length of time, so a tank that can fit into a car won't last very long, and probably won't provide enough benefit to cover its own weight anyway.
Why not extend the turbo intake out into a 4" or 5" funnel and have a 4or5" fan instead of the small one Stao tested, that way it will drive more air and once condensed into the smaller compressor opening it would have more pressure/density wouldnt it...
Why not connect a complicated belt and pulley system to some bicycle pedals in the passenger footwell so you passenger can pre-spool the turbo for you = on boost from idle.
or what about using a small model aeroplane motor fuelled on alcohol mounted in the turbo snout...
I love to see a super responsive 300rwkw turbo system...eliminate the lag
I was actually thinking a hi amp started motor that drives a cog attached to the turbine shaft.
This would just give a quick zap everytime you applied heavy acceleration when the turbo is off boost.
But now I think birds idea is much better :laugh:
Though maybe instead of pedals we could just have a hamster wheel with some well built guinea cops on roids
This Eturbo was originally thought to be a bolton "turbo" upgrade that can produce about 5psi of boost on a 2L or smaller NA car. In practice it is rather difficult, but developments are still been made.
Realistically the E turbo on a compound will unlikely to work unless it is a low boost application as the motor speed can not go beyond 40,000RPMs so's the bearing that is securing the shaft.
I'm still waiting to trail the new G3 version in both in and external gate on the 11th.
Nissan March Super Turbo
The Lancia Delta's
there are a few others but cant think of them right now
HKS did a kit for the 4agze aswell,
re: the air compressor..a crazy ex mate yrs ago tried it on his GTR, he had a tyre inflater air compressor, connected up to eleventy billion 2 litre coke bottles in the boot of his car, hooked up to a solenoid ..adelaide people may have seen it..lol...i don't think it worked, but man was it funny and loud..haha
cheers
darren
Ok got a new tune and it makes 280hp, boost still falling over.
If that is the case, you can send the turbo back and swap for some thing bigger, I won't charge you for the upgrade.
2x Small 12s 5000mAh Li-po batteries
How long will they run it for? I'm wondering how this would go on a 1000cc sports bike motor.
I run then for about 15mints and they are 85% depleted. If you run them off 2x 24V car batteries they should last for couple of hours in theory.
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
