A high pressure air reservoir could be used in just that way. Would need to work out a way not to have to squirt it into the exhaust housing (ie, some other sort of additional turbine on the same shaft would be good - or, left field thinking, squirt it tangentially onto the compressor wheel and hope it spins it up without interfering with the flow off the tips of the comp wheel). In fact, it has been done before in one way or another.
But, it takes a lot of flow to drive a turbo up to speed for any length of time, so a tank that can fit into a car won't last very long, and probably won't provide enough benefit to cover its own weight anyway.
Why not extend the turbo intake out into a 4" or 5" funnel and have a 4or5" fan instead of the small one Stao tested, that way it will drive more air and once condensed into the smaller compressor opening it would have more pressure/density wouldnt it...
Why not connect a complicated belt and pulley system to some bicycle pedals in the passenger footwell so you passenger can pre-spool the turbo for you = on boost from idle.
or what about using a small model aeroplane motor fuelled on alcohol mounted in the turbo snout...
I love to see a super responsive 300rwkw turbo system...eliminate the lag
I was actually thinking a hi amp started motor that drives a cog attached to the turbine shaft.
This would just give a quick zap everytime you applied heavy acceleration when the turbo is off boost.
But now I think birds idea is much better :laugh:
Though maybe instead of pedals we could just have a hamster wheel with some well built guinea cops on roids
This Eturbo was originally thought to be a bolton "turbo" upgrade that can produce about 5psi of boost on a 2L or smaller NA car. In practice it is rather difficult, but developments are still been made.
Realistically the E turbo on a compound will unlikely to work unless it is a low boost application as the motor speed can not go beyond 40,000RPMs so's the bearing that is securing the shaft.
I'm still waiting to trail the new G3 version in both in and external gate on the 11th.
Nissan March Super Turbo
The Lancia Delta's
there are a few others but cant think of them right now
HKS did a kit for the 4agze aswell,
re: the air compressor..a crazy ex mate yrs ago tried it on his GTR, he had a tyre inflater air compressor, connected up to eleventy billion 2 litre coke bottles in the boot of his car, hooked up to a solenoid ..adelaide people may have seen it..lol...i don't think it worked, but man was it funny and loud..haha
cheers
darren
Ok got a new tune and it makes 280hp, boost still falling over.
If that is the case, you can send the turbo back and swap for some thing bigger, I won't charge you for the upgrade.
2x Small 12s 5000mAh Li-po batteries
How long will they run it for? I'm wondering how this would go on a 1000cc sports bike motor.
I run then for about 15mints and they are 85% depleted. If you run them off 2x 24V car batteries they should last for couple of hours in theory.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
