When I took off I heard this voice say "your shifting to early wind the gears out"
Wonder who put that in my head was huh Jez
I admit it im a bad influence. But i am a good teacher, atleast u know when to change gears now u pussy :P
When it stops making power? hahaha at 300rwkw, I stop changing gears by the RPM, kinda have to play it by ear....literally. Far too focussed on the road.
He was changing at 5500 or some pussy rpm
I admit it im a bad influence...
Not really, I remember when u were tuning my car u kept telling me to take it easy n slow down as i was revving the sh** outa all gears so u cud tune the upper rpm points too.. Ur kinda good influence I reckon..
Docile every-day driving I usually change around 4000rpm, but the few select sections in this every day driving I give it what for as I would on a weekend - ~7000rpm shifts, not letting revs drop below 3500. hahaha though this is rare :(
Docile every-day driving I usually change around 2000rpm, but the few select sections in this every day driving I give it what for as I would on a weekend - ~2500rpm shifts, :(
because Diesel Van
Yeh the ss turbo's build boost faster but can't seem to hold it as well uptop. I had one of staos wastegate mods on initially but the boost wouldn't go below 20+ psi...
I'll wait for Jez to post the overlay graphs, but IMO the SS1PU comes on faster and has a better top end. Maybe you're thinking of the SS1?
I wasnt really expecting to get a result similar to an ss1pu, they are like $700 more and are a superior turbo. You would expect them to outperform a standard hi flow easily.
Im happy with the result, but if I ever get over this setup (highly doubt I will for a while) theres always the option to sell up and go bigger with something like gtx3076 later on if I wanna chase a larger number.
Edited by Mitcho_7
Haha ur a hoon
Had to chime in Jez, pot calling the kettle black anyone.............. :) :)
You've driven my car so I have first hand experience lol ;)
Ive never seen my semis so "ungrippy" heheheheee
because Diesel Van
hahaha yes :P though I'd say about 500rpm more than what you suggested. 2nd - 5th are all pretty long gears, and I've found there's really no need to wind it past 3000rpm in any gear.
Lmao Dave i have no idea what u mean :P
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
