Good luck with everything Hanaldo!
What is a decent low mount exhaust manifold to upgrade to from the stock r33 one? Ideally one that would allow the use of the same dump/front pipe?
Finally started car for first time after installing the ATR43 G2 in the car and I'm a little worried. First turned car on for short period (1/2mins just making sure all intake setup was alright and no vacuum leaks) and saw steam start coming off the turbo so turned car off straight away.
I hadn't put coolant in the car yet so I hit myself in the head then refilled it all waited a little while and started car again. Was letting it idle to bleed the coolant and again lots of steam started coming off the turbo pretty quickly. Am I being paranoid or is it likely my coolant feed has gotten blocked off? I am still using the steel lines and obviously had to 'adjust' them so that they would fit up to the new turbo.
It's more likely to be smoke. You most likely had a bit of oil on your hands or you dripped a bit from the oil line, which is now on the rear housing or the dump pipe. It will just smoke a bit until it burns off, nothing to be concerned about.
Mine bellowed smoke for a good couple of minutes burning all the shit that I put on touching it the whole time.
Give it a few minutes and it will go away.
If it doesn't then check all the water lines going to it.
99% it's going to be the dirty turbo
Yeap. Every time I do a turbo on my own or another car I get lots and lots of smoke as it burns off my grubby paw prints.
Just make sure you are checking for liquid leaks. No leaks, no worries, let it keep running.
Awesome thanks guys I know i def got oil and such on the turbo my hands were covered in crap haha. The turbo shouldn't get hot enough to damage it on idle even if it is getting restricted water going through to it do you think?? I mean the oil is still flowing through it and some turbos are oil cooled only.
I looked for leaks and didn't seem to be any which I was happy about
Just make sure the oil line supplied with turbo is used and actuator is tightly shut with preload. Then that will he fine. Water is optional, they also works fine with no water.
Check your heater drain hose isn't fouling against the turbo too, this will give you a burning rubber/mechanical smell when the turbo heats up. I tied my hose back with a cable tie and it's been sweet since.
could have also cracked a water line when manipulating it, pissing a small stream of coolant onto the rear housing/dump pipe
easiest way to tell: what does it smell like?
S1 R33
3 inch dump,high flow cat, 3 inch exhaust
Apexi metal intake pipe with pod --- problem?
China fmic --- problem?
044 fuel pump
660cc high flow injectors
Superspark coils with copper plugs @.8
Nistune ecu
Eboost street
SS1pu
277.0hp @17psi
There isn't any boost leaks, we checked while there. I also double clamped all the pipes to make doubly sure.
I did check at the time whether i pulled all the rags out as well.
It's got me stumped, any ideas??
Drop the exhaust, that seems way too laggy.
Brand spanking new Apexi n1 pro installed on saturday.
I know whats wrong. Because he's from Perth. :D
Could be, could be ;)
Although last week the egt light came on for 2 minutes, then went away. But i checked out the cat when i put the exhaust on and it looked ok (3 months old)
This turbo generally makes a responsive 260rwkws with 18psi of boost, confirmed by couple of members.
Pre-dyno tuning you should have:
Proper aftermarket ECU that is designed for the model of engine
It appears to me like a R32 ECU + Nistune with no VCT activation.
Mechanically sounded engine
Make sure compression are good, base timing is correct and matches with ECU data.
Spilt fire coil packs with correct “copper” spark plugs
Good quality fuel injectors and a good fuel pump with a new fuel filter.
Good and effective 600x300x75mm intercooler, that excludes most of return flows.
Have a feel on the cold end with your hand after each dyno pull. Good cooler remains cold.
At least 3inch “metal” induction pipe with a free flow pod filter. This excludes:
Re-enforced or modified based on stock rubber intake pipe
Random ebay cast metal pipe made for factory turbo.
Custom pipe that goes into a sealed factory airbox.
If above is what you have make sure you change it refer to working examples from this thread.
At least 3 inch free flow exhaust
Excluding certain restrictive cats
Excluding restrictive mufflers
Good way to test it is by dropping off the exhaust pre-cat. substantial gain means restrictive exhaust system.
The last thing is the Tune. There are bad tune related examples from Perth, and there is very little that I can help with, apart from sending you a Nistune map based on the same turbo for reference. Give a try at "All star garage".
If there is a sincere believe of a fault on the turbocharger, then I'm happy to have it fully tested on a good setup in return of testing result and tune map, any defects found will be repaired.
No way am i disrespecting the turbo, i'm just after peoples opinions as to what could be the problem.
I will try a new fmic setup and a 3 inch all the way intake though, the apexi one is 4 inch - 2.5 inch.I'm starting to lean towards the cat at the moment tho.
As far as the Nistune, it's out of a zx and vct is fine, timing was also checked at the tuners.
I'll keep scratching my head, i guess i was hoping for someone to say "that's what's wrong you f***ing idiot"
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
