89CAL Posted July 18, 2012 Share Posted July 18, 2012 Queit in here, must mean Stao is off designing more turbos Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6448705 Share on other sites More sharing options...
Manuel Kasko Posted July 18, 2012 Share Posted July 18, 2012 I was just coming back here to bump this and see how he was going. Any results on the SS1PU using e85? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6448729 Share on other sites More sharing options...
hypergear Posted July 18, 2012 Author Share Posted July 18, 2012 My engine head gasket went last night on the dyno due to a bad wiring in the fuel pump lol. I was about to test it out. So hopefully in about a weekish. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6448773 Share on other sites More sharing options...
Mitcho_7 Posted July 18, 2012 Share Posted July 18, 2012 i thought you were getting that fuel pump changed to avoid lean out issues? Either way, having to replace the head gasket sucks Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6448883 Share on other sites More sharing options...
hypergear Posted July 18, 2012 Author Share Posted July 18, 2012 The new pump requires an additional earth. By the way it is a walbro F9000262 400L/Min pump. It works once plugged into the stock loom but doesn't create much pressure. Once additional earth is connected it worked fine. How ever didn't help the head gasket. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6448933 Share on other sites More sharing options...
Birds Posted July 18, 2012 Share Posted July 18, 2012 Don't know why people use anything but the good old 040. Never heard someone complain about one! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6449309 Share on other sites More sharing options...
DJSimmo Posted July 18, 2012 Share Posted July 18, 2012 Don't know why people use anything but the good old 040. Never heard someone complain about one! Cant forget the Nismo pump, it plugs right in, is good quality and pumps and decent amount of fuel Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6449470 Share on other sites More sharing options...
Kinkstaah Posted July 18, 2012 Share Posted July 18, 2012 Having used three of them in the last week I have nothing bad to say about them other than that they are driving me mad by failing right out of the box due to clogging! (I realise this is not a pump issue ) Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6449473 Share on other sites More sharing options...
scotty nm35 Posted July 18, 2012 Share Posted July 18, 2012 Birds, even the 040 needs a good power supply, in fact I would be upgrading the power for any aftermarket pump as they require up to 4 times more current. Stao found out the hard way that the stock wiring can't supply 17 amps. Sorry to hear mate. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6449511 Share on other sites More sharing options...
Hanaldo Posted July 19, 2012 Share Posted July 19, 2012 Don't know why people use anything but the good old 040. Never heard someone complain about one! Because we are cheap bastards Birds Do wish I had gone with the 044 back when I did my fuel pump, didn't think it would be necessary at the time though. Nor did I realize how good a noisy fuel pump sounds!? Interesting that it failed on the dyno though, was the fuel pressure not being monitored or is it just one of those things?? Makes me want to check my fuel pump, though I have rewired mine and has been sweet so far. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6449775 Share on other sites More sharing options...
hypergear Posted July 19, 2012 Author Share Posted July 19, 2012 I had 040 in my Sil180, when the metal filter blocks it makes a loud whining noise. I had to pull it out and clean it once every couple of weeks, on the end I teared the mash filter out of the bottom and that worked fine and stopped the whine. lol The walbro more or less bolton to stock bracket, and it had an walbro in there for 4 years without much issues. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6449833 Share on other sites More sharing options...
Birds Posted July 21, 2012 Share Posted July 21, 2012 Because we are cheap bastards Birds Do wish I had gone with the 044 back when I did my fuel pump, didn't think it would be necessary at the time though. Nor did I realize how good a noisy fuel pump sounds!? Interesting that it failed on the dyno though, was the fuel pressure not being monitored or is it just one of those things?? Makes me want to check my fuel pump, though I have rewired mine and has been sweet so far. That's what I mean though...040 is so cheap I don't know why people don't just go for that. Still using stock wiring at 260rwkw, no issues with fuel supply...will see if it lasts when I switch to ethanol. Must have had a dirty tank Stao, or had the pump sitting right at the bottom. Nearly 2 years on and mine never whines! Unrelated: gearbox running in period approaching it's end; have been giving my car more frequent bursts of full throttle. I've said it many times and I'll say it again, SS1PU ftw. Lastnight was cold as ice and she was throwing my mate back in his seat hahahaha. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6452882 Share on other sites More sharing options...
DVS JEZ Posted July 21, 2012 Share Posted July 21, 2012 If u put a flow gauge on aftermarket pumps with engine running u will see how much upgrading the wiring helps. Yes u can just do the earth mod but i always prefer running a relay with a strong battery supply. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6452966 Share on other sites More sharing options...
Hanaldo Posted July 21, 2012 Share Posted July 21, 2012 That's what I mean though...040 is so cheap I don't know why people don't just go for that. Still using stock wiring at 260rwkw, no issues with fuel supply...will see if it lasts when I switch to ethanol. Must have had a dirty tank Stao, or had the pump sitting right at the bottom. Nearly 2 years on and mine never whines! Unrelated: gearbox running in period approaching it's end; have been giving my car more frequent bursts of full throttle. I've said it many times and I'll say it again, SS1PU ftw. Lastnight was cold as ice and she was throwing my mate back in his seat hahahaha. Why not rewire yours? It's cheap and easy to do. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6453073 Share on other sites More sharing options...
Birds Posted July 22, 2012 Share Posted July 22, 2012 No need to, yet Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6454416 Share on other sites More sharing options...
Hanaldo Posted July 22, 2012 Share Posted July 22, 2012 No need to, yet Wouldn't wait until there is a need, by then it will probably be too late and a whole lot more expensive. You're probably wearing out your pump a lot faster by running it at low voltage, Bosch do say to run it at a minimum of 13.5v. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6454427 Share on other sites More sharing options...
LANDSCRIBBLE Posted July 22, 2012 Share Posted July 22, 2012 Why not rewire yours? It's cheap and easy to do. is it the one where you wire a relay between the battery and the pump? there is a tutorial in the DIY section for that one. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6454443 Share on other sites More sharing options...
adam999111 Posted July 22, 2012 Share Posted July 22, 2012 Hi, going to book a tune this week, just wanted peoples opinion on an ECU, I currently have Power fc with Z32 afm. But i was thinking to go down the path of Adaptronic and go with a MAP sensor? What are your preferences, to help me make a decision, as i dont know what to pick. Its only between the two so please don't recommend another ECU Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6454508 Share on other sites More sharing options...
DVS JEZ Posted July 22, 2012 Share Posted July 22, 2012 Both will give the same outcome. But u could sell the power fc, afm and boost controller if u have one and use the adaptronic with boost solenoid so it controls boost Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6454528 Share on other sites More sharing options...
adam999111 Posted July 22, 2012 Share Posted July 22, 2012 I'm not going to be using a electric boost solenoid, so that feature will be void, but for tunerbility and power potential, would AFM (power fc) or MAP (Adaptronic) be better? If they are similar and outcome will be the same as you say, is it worth the hassle of selling the setup i have now and going Adaptronic? On a side note, Adaptronic uses wasted spark, will this affect life of the coils or produce a lot more heat in the engine? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/285/#findComment-6454539 Share on other sites More sharing options...
