For $500 you'd want to be ale to demonstrate a significant improvement in power and/or response. Exactly what "significant" is is up to you to advertise and the consumer to decide if it's worth $500.
As he said himself, the benefit was less than that of a china manifold and he wont be providing that option to people.
Without a side by side comparison against a stock manifold, Stao will struggle to sell any.
"It performs nearly as well as a no name China manifold" isn't a satisfactory response to "what benefits can I expect above and beyond my current stock manifold?"
There is too much variation between "China' manifolds to be able to use "them" as a benchmark. Stock is the only acceptable benchmark.
Not too sure what you're trying to achieve? He did say he's not selling them because there were no substantial gains.
In car:
Above is a China manifold, the one that I've had before Brae's manifold. and it actually worked exceptionally well and I've made 330rwkws of it based on a G3 on pump 98. This manifold is only $350 to get from China. It fits on stock position and bolt the turbocharger on factory position. This might be some thing I will be looking into in near future.
Well that level of gain Its not worth the $500, a cheap china manifold would've gained better result. I won't be providing that service.
If you open your eyes, you will see that his exact words were that a china manifold will produce a better result and that the $500 outlay is not worth the gains. Stao has clearly said he WILL NOT be selling those manifolds.
I suggest that you apologise to Stao, because you are clearly coming off rude and it is really uncalled for. Stao built that manifold for the benefit of the SAU community, and he himself admitted it cost too much for the benefit it gave.
Dude are you trying to be a deadset potato here?
Ok, I miss-understood.
I wasn't having a go at Stao, I'm a big fan of his work. I though he was saying it's not a worthy upgrade from a China manifold which I then assumed it was still on the cards for a stock upgrade.
There was a little bit lost in translation.
Settle on, it was a simple miss-understanding.
No need to start throwing insults.
Stao do you make or could recommend something for 4.2l diesel landcruiser?
I would use a ATR28G2 in a .86 rear housing.
and for the link earlier it appears to be the same manifold. Mine has been coated before I bought it, it was from a guy in Aus.
Since its going to take another 4 hours to re-install the brae manifold. I might do further evaluation.
Using stock manifold, car made a one time maximum of 303rwkws with ATR43G3 none FNT turbo on pump 98. I will be install the same turbocharger back on and do one more run. Based on that I should be able to get the exact amount of gain if there is any.
Plus I've already got the result with the same turbocharger running the China manifold, so we can compare against all three.
Hey did you do anymore on the internally gated kando TD06? or did I just miss the discussion.
If it worked as well as internally gated garrets you would be onto a real winner.
I dont think he did an internal gate TD06, that would be interesting.
Into one of his RB specific housings, might sell well with the billet 20g wheel.
Stao you should set one up just to see. Im sure that you are capable of profiling the housing to suit, after all your FNT experience!
I think Trent had few internally gated runs and they were no good. Had a look at some of the internally gated SL2 and even T518z on NS and they are no where near what they are externally gated. They are not some thing made to internal gate.
besides all the Gx, SS1PU and SS2 units works well enough on ever manifold internally or externally gated, not much point re-engineer some thing's already been done.
But having said that I will drop the billet TD06 into .82 type B rear for curiosity sake when I have some spare time. Or let me now if any of yous would wish to trail.
Some updates for the externally gated series:
Great news as I've managed to find few suppliers whom can produce TD06, and T518Z housing and turbine wheel castings. We will have some of those housings brought in and finalize machinery work locally. I will also invest some time in making up CNC drawings for billet compressor wheels.
By the end of this month we should have billet version of both TD05H 18G and TD06SL2 20Gs in T518z (T28) housings, TD06 20 and 25G in both 8cm and 10cm in T3x turbine housings.
Price will stay competitive against Taiwanese producers, we will use our FNT turbine setups as well as custom wheel profiles archiving greater response with higher power level. All turbochargers will be made to order in strict time bases, great support and customer services as always, and we won't be blocking any one on ebay.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
