Stao what are the changes to these new SS1 and SS1.5 compared to my current SS1PU?
Can you please confirm sizes. Feel free to PM if its better.
SS1 is in 60mm, SS1.5 is in 64mm, while SS1PU is in 71mm.
Both wheels has 3mms in tip extension, customized hub.
The 60mm wheel has the equivalent blade size as the current 71mm cast wheel, and I've added couple degrees crop to the top so it won't be maxing out so early working with a Rb25det. This wheel should be excellent for people targeting 200~240rwkws on stock camed Rb20det/SR20dets.
The 64mm is a smaller version of the 71mm, how ever there isn't a lot of difference to the inducing and exducing area as most of that diameter has been taken out form the center hub, it does have very sharp throttle response, probably won't have as much top end, hopping to see bit more areas under the curve.
Went to a quite spot today and spent some time modifying the top left corner of my map as its caused some issues since dialling my cams in. I then added a bit of fuel across the entire map so I could open it up.
It used to hit 10psi at 3550, 14psi at 3800 and 17 at 3900
Today visually using rpm on controller and gauge I saw 14psi at 3500 and 17 at 3700. My controller is at 17 currently so it might have built more if it wasn't already tapering off.
Stao's 98 result on stock mani was 14 @ 3450 and 17 @ 3550 so I'm right there with him now. Just waiting on exhaust to be built and for me to make a cold air intake before retuning :)
Edit: oh and for me to wire up the water/meth controller
Edited by t_revz
Just thought I'd post to say that I got my car tuned by Toshi today and my god, the ATR43G3 is an amazing turbo. The response and power is great and I'm only on 16psi. Only did a road tune so I dont have power figures but I'm satisfied.
When I get it on the dyno I'll throw up a print out
Thanks for the feed back. And Happy new year to every one, Best wishes and more power cranking.
in photo is our OP6 high flow using SS2 CHRA:
Balanced using our brand new Dynamic turbo balancing machine with VSR cradle.
Stao I've been meaning to ask, what CHRA do you normally use in your 2IU highflows?
Also, my SS1PU SR is booked for its tune on the 15th. Hopefully a healthy result coming soon.
Thanks Stao, thats pretty cool info :)
Might try get a friend to consider one. I have had a lot of other people tell me the 2IU highflows you make work REALLY well. Testament to your work. I was just curious about the specs.
Yes can be done. Can also balance RC plan rotors, and remote control car wheels. lol
Further update, this is relation to current bearing setup. I'm trailing couple of high tensile steel ball bearings, as well as few different types of brass bearings that I've made earlier. Will upload result once done.
Nice looking BB cartridges Stao. Do you expect the BB's to make a huge difference? I've used bush and BB turbos before, but never seen back to back comparo of same turbo from same maker, so I'm very interested to see it.
Doesn't make much differences on the dyno. but in road driving there is a small difference in throttle response. how ever I'm pretty concert with the life span with those bearing specially when they are working in a hot environment with high speed and heavy thrust load.
In the bush bearing setup the centripetal and thrust support is the oil pressure supported by oil pump. So the bearings don't necessarily worn unless the pump fails or the oil has hard objects. I'm trying to get the same throttle response as the roller bearing through modifying oil galleries on the bearings and bore.
Can be done. Result in page 320. How ever only for evaluation at this stage.
Trent is Finally back, should have results for all 3 new turbochargers by weekend.
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
