Stao, something that hasnt come up in a while: Variable Geometry turbos
I think last time you talked about this it was on hold due to the complexity of the task (Understandable of course) but was just wondering if theres plans to do anymore development with these this year.
In a manual we don't usually sit on the 2~3000RPMs range, how ever the autos do use that quite often and with the long gear ratio and high drive tran lose, It acts as if it needs a tinny baby turbo down low with a huge turbo up top.
Unfortunately any thing smaller on the exhaust side is going to sky rocket upper range EGT while smaller comp will reduce top end power.
Roller bearing has no effect on the SS1xx series as the bear friction in those are already sit to be minimum. It probably need a VNT valve in the exhaust housing. I might be able to get that working and driven by an actuator.
Is there a twin scroll housing option for the ss1PU?
.... you know where I'm going with this :-)
cheers
Justin
f**k yeh...a hypergear makes it to the drags..haha
and nice work scott, sound like a fun setup
cheers
darren
Here ya go man, 13.6 at 176kph. Just couldnt get the thing off the line nicely last night. Will post some videos later of what i mean.
Need to track down a weighbridge.
Have a full tank and nothing extra in the car that you wouldnt have when your at the drags.
Plenty of public weigh bridges around Perth, Landscribble.
Has anyone heard from Stao, sent a couple of emails off regarding eta on my turbo, haven't heard from him since mid last week.
Yea might do Martin. I wonder if i could adjust the rear spring settings to make it less stiff, would that help with axle tramp? I had the dampers wound all the way down (soft). The launch control wasnt doing me much good with mickey thompsons on. Rpm limit set to 4000, dumping the clutch it would grip within a second and just bog down at 2500-3000rpm, i dont get any power until 4400 lol..
With Mickey Thompsons try closer to 5500rpm launch mate.
having the dampers set all the way down isnt necessarily helping. thats not how suspension actually works.
you want the car to absorb some part of the power and to squat plus stay squatted.
having your damper set to zero is just gonna let the car bounce and rob you of power off the line whilst inducing wheelspin.
turn the dampers back up until you can feel the car solidly squat and stay down on a decent launch. A nice firm squat, not a free fall to the floor.
Must not making alot of power atm for that mph, Stao should take his to drags..should do upper 120's...
cheers
darren
What was your 60ft? With worn semi slicks and circuit spec Bilsteins I ran a 12.9 @114mph with a 2.2 60ft with about 234rwkws. I didnt launch the car hard as was worried about std RB20 box. Just ride the clutch and touch the limiter in 1st if you are getting wheelspin and shift smoothly, not snatching or you just rip skids :)
LOL, thats my advice having done all of about 10 qtr mile runs in my life :) (oh my car weighed 1345kgs with 10L of fuel in it at PI weighbridge)
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
