I reckon the delivery of the turbo plays a definite part in the ET, and the on-off responsiveness between gears in the trap speed and ET for sure. The G3 as Stao says has good 'rush' up top, but a little lazy in and out of gears (on stock manifold low mount I mean) and kind of like a light switch delivery in 1st and 2nd which makes juggling bog/wheelspin hard off the line.
And obviously driver experience at the strip :P
+1
It wasn't easy to get off the line- first run i bogged hard and the next I fried the tyres. I think I'm going to need a fair bit of seat time to get the launch right!
Yeh I think Luke's and my trap results are very effected by boost response between gears. Took the car for a drive the other night and tested that out, and I've got about half a second to a full second of lag between each gear change.
Block up BOV helps.
The launch won't affect you trap speeds much most 1-2mph the better you launch better 60ft you trap speed will be lower
But yes it will affect you et I think its for every 0.1 quicker off your 60ft it's 0.2 off your et
So you will need a 2.0 60ft and you will be in the 12.8 but proberly 113 or 114mph
SS2 FTW!!
This is the latest G3 turbocharger. It has stepped down back to a 56T from 58. I've focused it on better throttle response and transition response.
The prototype about is built in ball bearing. It felt pretty good on road comes on boost with very light throttle. hitting the dyno again on Wednesday and see how it goes.
Yes it has stepped down to 56T. No point going for a 58T if majority don't have a setup and a engine for that extra power. This one was focused on throttle and transition response. It makes an great every day road turbocharger within the budget.
This casting is in steel as usual.
I'm dreaming of the day you trim down the turbine to something under 80.... I think that would work better for response again.
The sl2 wheel is 61mm with a mid 70s trim. You saw the response on that vs your ss2 when they were running the same compressor... Just do eeeet
Well it made 30kws difference in power with less boost compare to the L2 turbine. Also peeks boost at the exact same RPM which is pretty interesting (Do have slightly lower RPM to Boost ratio before that point, result overlay at page 351)
This turbo needs to be able to work internally gated, So reducing the trim on turbine end will probably hurt that. Small trimmed turbine might work ok on smaller SR and Rb20 engines, When you are bored of the SS1PU and ready for a high mount I can trim one for you to your recommendations.
You just need to tell me what housing to supply, as I will be buying the Tial housing soon.
At the moment I was going to buy a .64 suit GT28, but if you want me to get a GT30 spec housing just let me know. Yet the GT30 are 60mm 84 trim, so we might be better off using the .64 GT28 housing anyway so we can profile it up. The GT30 housing would need a sleeve which I am not too confident in doing.
Can you tell me the specs of your highflow turbine? From memory its a 60mm but different to whats in a G3?
Welcome to A Brand new all better and all mightier ATR43G3 turbocharger. The Older 58T version is now retired.
This turbocharger have out performed the older profile of the G3 in both peek power and response. Both turbochargers had roller bearing cartridges installed.
Thin Yellow and Red (18psi) is the latest G3
Thick Yellow is the older 58T G3
This turbocharger stopped making power at 376rwkws @ 23psi.
Congratulations. That new turbos certainly do produces a wide spread curve, making 240rwkws @4000 rpms. It would be a hell lot of fun on road. Great to see the improvement stao. Good work. :thumbsup:
Stao,
Are these results comparable? Ie. your new setup is on an aftermarket highmount manifold and externally gated, did you test the old profile G3 on the same setup or is this new result vs the old stock manifold/internal wastegate result?
Highmount/external by looks, i want to see internal gate 56T vs 58T on stock manifold, thats what most people have/buy..
Also going back to the 56t, originally you where saying the 58t needed cams for more power from memory,
but going back to 56T and still giving samish results, have you actually run out of turbine flow?
cheers
darren
Edited by jet_r31
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
