Is that an aluminium elbow welded on there? 2.5"?
Yep ebay china spec..same as comp cover lol, ive been playing a game with this car,, try keep it cheap as possible, but also make shit last since its a roadtrip /family
car, that spend all its time in the hills, i didn't feel like replacing a 90 degree piece of silicon due heat every 2 ish yrs, hence the alloy 90, and its moves it fair away from standard,and higher aswell, just all fitted still with longer silicon joiner and a twist of stock intercooler pipe.
Braided cloth oil return, aluminium elbow, steel factory water lines, some ACL GTR heatshield on things, i am hoping i don't have to do no maintenance besides changing oil ever 5000km
cheers
darren
Edited by jet_r31
lol go the giant external gate daz
haha...its was free..i had a old school 45mm turbodumb aswell sitting around .it did not fit as it was to tall, if i bought one i would definitly get a tial 38,
more flow and valve lift in same package. I hate internal gates.
90 percent the of the stuff i got is s/h or sitting around my shed , except for turbo and scotty intake (which fitted well, even though i changed the cooler pipe route, it still has 10mm clearance .Same as bloody silicon..i wanted black, but i found a big piece of blue
in the shed..so i am using that. I am not scared of boost , if it makes power at 23-24psi, its coping it,
Staos auto record better get smashed..lol
i upgraded the wmi to a 600cc jet and may put it pre-turbo for testing , hopefullly the fat pig runs some 12's, i wanna see results, can't wait to smash it on the wastegate..lol
cheers
darren
Edited by jet_r31
yep, i lol'd, i bought it as its the only turbo Stao didn't change as much as his underpants..then i fitted it and he changed it...hahahahaha
Oh well, it will be better than what was on there, when i pulled it apart, the turbo bolts where loose , the exhaust mani bolts where loose
and the turbo side intercooler piping was not done up..it was laggy a f**k and whistled like a kettle for last 12 months, i just
cbf'd tracking it till i did turbo change ...bloody japanese muckanics..lol
cheers
I bought one of those hypergear modified Td06 20G billets for my 4age turbo aswell Scott, got a 8cm housing for it
cheers
darren
Edited by jet_r31
LOL! how does it freaking get that bad..
admittedly tho, i got a cooler put on my car once and got it back from the mechanic with the two rear turbo bolts undone. the tabs had been pushes back and you could see the marks of double hex sockets being used on a long crooked extension.
never want to have work done by a mechanic ever again, unless i absolutely have to.
if mechanics can f**k things up then why cant i? :P
lol generally i can do anything necessary.. yet that particular job was a FMIC on an NXR, which had to be custom. So they were employed to make up the pipes etc.
Turns out they wanted some return business.
ive done countless motor swaps and conversions myself, including a full build on my current SR. that was truly a one off. I may even learn to make my own pipes, screw having someone try to bend me over like that again. FYI I fixed that myself too lol kents
Just get an NPC organic, will handle 300kWs easily. Just talk to a fella name Doug from NPC, he's pretty cool!
I decided to be stupid and get the carbotic version, going up shopping centre carparks usually result in hops or chirps LOL
NPC 10" sprung button in my car for near 3 years now I think. Been handling 255rwkw easily. Never had any issues and couldn't be happier. If you have the money go the lightweight flywheel off NPC as well
I've heard good things about NPC before, but don't really know much about specifics of their products.
You got Doug's contact details Johnny? :)
Here you go :)
[email protected]
07 3277 9403
Ask for Doug, I'm sure he has dealt with many Skyline fellas in the past. He said the organic will easily handle 300 kWs, and the carbotic up to 400kWs.
He didn't disclose too much information, but from what I can tell the pressure plate is either from a 300ZX or a Patrol which they apply some magic too. This increases clamp but doesn't affect pedal feel, to be honest my pedal feels as soft (if not softer) than a standard Exedy OEM Replacement clutch. Also from my experience, the NPC 10" Carbotic is a tad more forgiving than a Exedy (NC10T) Sports Ceramic (4x puk from GT-R on a GTS-t). I can take off from slopes without looking like a moron LOL
So no need to waste money on NISMO pivot and NISMO slave
P.S. I don't work for NPC, but buy from them directly cheaper than resellers
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
