Probs a stupid question.....
But what is the price differance between a Garrett 3076R to buy and the equivilant Hypergear item say SLSS2 or SS2 which seems about the same response and kws etc??
Read back through previous pages and look at the dyno printouts. Hell, even better would be to look at the RB25 Turbo Upgrade thread.
Don't mean to sound rude, but seriously it's not fking hard.
I would go a Hypergear over my old 3076 the power delivery of the 3076 on 98 was way to linear but taos magic slss2 was so much more fun to drive with its aggressive delivery didn't notice any difference in lag and that's both on a rb25 with stock manifold internal gate and a return flow cooler obviously with other support mods
Hypergear ftw
Thanks for the feedbacks.
Here's a set of GTR high flows that Ive done recently. Using ATR28G1 chra, which is in 60mm comp and 56mm turbine
Also there is a update on all R33 and R34 turbocharger high flow profiles. I'll be going up in one size up from the standard high flow. should increase power by about 10%.
Also ATR43SS3 VNT turbocharger is built. This time the lever is working 100% with the actuator it can be activated with about 5 psi of boost under load. I should've taken a photo before installation, but I guess I'm too keen to trail it on road. Feels pretty responsive, hopefully be hitting close to 400rwkws with full boost around 3500rpms.
Is there are actually a break down page showing all the HG varients? The names make absolutely no sense in regards to power or features - that I can tell, and there isn't a place I have found which allows someone to look at and get an indicator of whether something is ball bearing, journal bearing, billet, cast, bolton or universal etc etc... just random names that someone has to follow this thread daily to understand. SLSS2 vs SS2, etc - PU? FNT? what does it mean?
Maybe the first post in the thread could be updated as the varients change so one can go back there and see what is currently on offer? Apologies if there is something like that somewhere I haven't looked, but amongst other things I'd be much more likely to recommend HG turbos to people if I could make sense of the naming and specs - I don't really have the time to follow all the posts as new names and new specs roll out.
Cheers
They are coded in pretty simple terms, I guess I should have made it more transparent.
ATR: Just a name standing for "Advanced turbo research"
followed by: "Turbine pattern" "Type of comp wheel" "HP rating" "Turbine type" "Bearing type"
"25": .64 and smaller T2x turbine housings
"28": T2x SR20det turbine ended turbochargers
"43": T3x universal turbine ended turbochargers
"G" Cast compressor wheels:
G1: 320HP
G2: 450HP
G3: 500HP
G4: 600HP
"SS" Billet compressor wheels:
SS1: 350HP
SS1.5: 400HP
SS1PU: 470HP
SS2: 500HP
SS3: 550HP
SS4: 630HP
Like the SS2.5 high flow: SS2 500HP compressor working with a Larger then usual (G4) turbine wheel made to extract power from tinny turbine housings like the 21Us.
"": Usually they are built in journal bearings
"BB": Steel Roller bearing
"CBB": Ceramic roller bearing
FNTA: Fixed turbine nozzle with wide opening angle (More power, less response)
FNTB: Fixed turbine nozzle with narrow opening angle (Better response, less power)
VNT: moving turbine nozzles.
Eg:
ATR43SS3BB.82VNT
T3x based turbocharger
Billet wheeled compressor in 550HP range
Steel roller bearing
.82 turbine housing
Moving turbine nozzles.
And
ATR43G3 .82b
Cast compressor wheeled in 500HP range
Journal bearing
.82 turbine housing with narrow opening angle
High flow codes:
Standard basic high flow.
"PU": Powered up. including larger .82B turbine housing and stronger actuator
"SS": Billet compressor wheeled high flow profile.
Eg:
R33 PU high flow. Means a customized 500HP high flow that has an .82 type B turbine housing with a stronger actuator.
Recently introduced turbochargers: ATRSLxxx
SL: L2 turbine ended turbochargers followed by volume size: 8cm, 10cm, 12cm
20.5 / 25.5G: Redeveloped billet compressors based on the original wheel
SLSS2: L2 turbine ended turbocharger using SS2 compressor front end.
FNT, VNT, CBB and BB extensions can also be added to ATR"SL" category if they've been built that way.
G1: 320HP
G2: 450HP
G3: 500HP
G4: 600HP
SS1: 350HP
SS1.5: 400HP
SS1PU: 470HP
SS2: 500HP
SS3: 550HP
SS4: 630HP
Eg:
ATR43SS3BB.82VNT
.82 turbine housing
And
ATR43G3 .82b
Journal bearing
High flow codes:
Eg:
Awesome, thanks for the response - that makes things a lot clearer and probably handy to have around.
I could see that being rearranged into a tabular form. Frame types down the left side, features (FNTA, FNTB, BB etc) across the top. Power expectations and response information contained in the various intersections in the table where turbos exist (because there will no doubt be some empty cells). You could colour code it so that external gate expectations were different from internal gate, etc etc.
That looks awfully familiar especially with the two studs, I dont suppose it is mine? :whistling:
Got mine on Monday which was good, just need to bolt it all back together now.
i have to admit, i like your turbos..but the naming drives me crazy and doesn;t make much sense unless you look at this thread
It makes it very hard to sell as a product
cheers
darren
I agree. I don't run one of your turbo's, but judging by the feedback on here I know you are putting out some great products with fantastic service to match, not to mention you are obviously putting a lot of R&D into your products. I do think however it would be worth considering coming up with naming convention that is broken up into distinct series and generations to make it clearer what your are offering. I have always been a bit confused :P Maybe its just me!
I think part of the issue is the constant development in his forever improving line of turbos.
But I do agree.. a simple size based model code would make things a lot easier, with one to two character designation for identifying variants.
ie 6074-SS for the SS2, and 6076-G3 for a ATR43-G3.
That way sizes are known by the model code and we can tell if the the turbo is a cast or billet item. An advance in technology should just supersede the older model.
Just my view point.
Some SS3 VNT update. The system worked perfectly and I was been able to control nozzle movement through an ordinary boost controller.
It made 394rwkws on 23psi of boost so far
I must address this result was archived by a large size turbocharger using stock cams and stock cam gears and boost. It is not enhanced through larger cams or cam gears.
ss3boost.jpgAs shown, the boost behavior in reference to degrees of freedom given by the actuator controlling the VNT nozzles. The whole boost curve shifts to the left as the nozzles stayed in the deactivation position for longer. How ever by doing so it also made the exhaust gas temperature very hot.
As we were adjusting the boost controller for dyno runs the car experienced some ignition problems so we had to call it a day. It will go back for any other run once I have it rectified.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
