What if JEM's dyno reads higher and they simply don't like tuning road cars that close to the limit? As you say, without both cars on the same dyno at the same time there are too many variables. Even strapping the cars down hard hurts performance on the rollers. I don't think Trents dyno is overly happy, perhaps within 10kw of everyone elses at that power, which isn't bad for a hubber.
Stao was having all sorts of issues getting a decent power output with the stock mani, once he changed it really opened up the top end, no matter the turbo.
Oorrrr what if JEM tune it more aggressive and it actually reads WAYYYY lower? Btw, there is no way I am suggesting that as indicating someone is squeezing SUBSTANTIALLY less power (ie 20-50kw) all other things being equality is ridiculous and I hope you are joking :P
Yeah agreed, Trents is very "reasonable" reading - have tried it myself and SAEJ1349 definitely reads significantly lower than the other correction methods but doesn't mean another dyno won't read lower. I'm not saying it will either, but there is a huge list of results there to build trends from.
I am not digging here, I am just OCD about getting facts straight so I can work out what to expect with this kind of thing - and it'd be a shame if people were deciding between two turbos (they can both be within the HG range) expecting x result and end up with x - 10% result. The numbers we are seeing here are very very good, especially for the money - and are genuinely giving more expensive turbos a bit of teaching... with recent results my curiosity is now more than piqued which is why I am trying to nail down a way of interpreting them. If someone has something more substantial than "Maybe JEM get way less power from cars" it'd be helpful to hear, as I would not hesitate to start pushing HG turbos locally. The same kind of process is what got me a fan of HTA turbos :)
BTW, the results from JEM we are talking about are FAR from having stock manifolds....
In 9 months time 5 years will have lapsed and I will be almost legal to drive again.. With the excitement of being back on the road I am sure I will make a road trip to VIC sooner or later, so will get a reading there if Stao can cover the run.
I will get a run done at JEM also (out of my own pocket) to compare between them and Unigroup for my own curiosity.
That should solve the puzzle for all :) We just need to wait.
EDIT:
As a point of interest... Stao had tested the SS1PU turbo on an SR at chequered also, which got 225kw on stock cams and 26Xkw on 272 cams..
My motor is fresh and was given a run in tune on a 45 degree day, with 256 cams I managed 234kw. I remember how the car felt on that day.... And know it is an enormous increment different to how it feels on a sub 30 degree day. I am confident I will walk on the test done at Chequered, and my tuning is done at Unigroup.
That would be pretty cool if you did do that, I'd be really interested to see the result myself. If I lived in Oz I'd do similar, we don't have Mainlines here (that I am aware of) and Dyno Dynamics are FAR inbetween. So when I am over I'll be more legal to drive on Oz roads than you? Roadtrip? ;)
Lol good man! Will be interesting :)
Lol keen much?
LOL this will be true. I can possibly arrange rego for then also, but its a 10 hour drive to VIC (plus the medial suburban shite) and I thought you had a full up schedule?!
Haha but that would be cool I must admit.
Hey Stao
My mate has a Pulsar GTIR with a built engine, i think he currently has a GT2871RS ( not entirely sure )
He wants more power, and still keeping the god dam quick boost he has.
Do you do anything for the gtir?
Or possibly rebuilding his current turbo with better internals.?
Well I didn't find there are much differences between Status dyno and Mainlane they all within 5kws. The mileage reading from quarter mile run is a pretty good prediction for power level.
With ATR43G4 that I made 431rwkws with, that was running 28psi of boost. The turbocharger is equivalent to a 3582 in .70 comp and .82 turbine. its not much different compare to others using the same turbocharger at given boost level.
The SS3 is a large turbocharger, So it is expected to out put that level of power, Try the FP 3076 with a solid .70 none anti surge cover, it should be maxing out the same result using a lot less boost.
Had the CAS replaced, and the car is running fine now. It had the SS1PU down low feel and went crazy after the external gate opens. The Micky Thompson are now hopeless, wheel spinning from 4000 and on wards in third.
Hey Stao
Do you do anything for the gtir? Or possibly rebuilding his current turbo with better internals.?
Can run a ATR28SS1.5 that should be a more responsive version of the GT2871
I know that Unigroup's and DVS-JEZ's dyno read within a poofteenth so results from them are fairly comparable.
We were going to run my car on Jezs one day back when Kurtis was in NSW which would have given another comparison but I think that's unlikely now...
These truly are the turbos built perfectly for our motors. I usually run 14psi all day every dsy with my ss2. Yesterday I wanted to test if the knock occurs on high boost and if it occurs earlier. I cracked out 18psi. My god this thing is brutal and it was on a slight uphill road. I remember after jez tuned my car we drove around on low boost which felt nice and strong plus better than my old tune. We kicked it into high boost and shit went off. Ive been in a r33 with a gt3582r and I can tell you that the ss2 dominates in every which way. Response, power delivery and driveability. You also dont need to run such high boost to achievr this. My old tune was 10psi and was making 244rwkw. Not many turbos will push that out of an rb.
I cant run 10psi to check :ph34r:
Just found out the vacuum hose to my external gate was melted as it was touching the dump pipe. lol. that explain the strange wavy boost curve. Taking it back for another tune and posting more result next week.
Lol, i was working around that area on my car and found a few melted bits :( Ill have to work on the heat control a bit better too......... Your dump wrapped?
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
